Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Evo Classic Models
Evo Classic Models All Evo Models
Sponsored by: J&M Motorcycle Audio
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-04-2009, 08:59 PM
Dr.Hess Dr.Hess is offline
Yeah, the drain is the dead give-away in your case.
Do keep in mind, however, that our bikes are subject to The Dreaded Click, as John and Rufus mention, caused by about a dozen electrical connections between the battery and the starter solenoid coil, including cheesy push connectors, switches, breakers, ring terminals, a relay, etc. After you have this drain tracked down and fixed, and remember that with a 20 amp-hour battery, a .5 amp drain means it's totally dead in a maximum of 40 hours and likely dead enough not to start the bike in 12 or 24, then if you have problems with slow turning over or a chattering solenoid, put a volt meter on the pull-in coil of the solenoid and see how much voltage is there when you push the starter button. If it's less than 10 or so, like say, 8, that could not be enough current available to pull the solenoid in enough to make good contact for the starter motor. Put the volt meter on the wire between the solenoid and the starter. That should read the same as the battery when you're cranking, give or take a little. If it's 8 and the battery is 10 or 11, the solenoid isn't making good contact. A brand new solenoid will do this if the pull in circuit doesn't have enough power available.
I spent 2-3 weeks tracking that whole circuit down. I added an additional booster relay to supply 12V to the starter solenoid and I have not had a Dreaded Click since.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
Dr.Hess
1986 FLHT: S&S carb, Andrews EV1
1987 XLH 883 Hugger (Wife's): MegaSquirt Fuel Injection
www.drhess.net
Old 10-15-2009, 09:01 AM
ozzie65 ozzie65 is offline
Hang Around
Default Update
Well, with the weather going to the dogs, I had a chance to dig a little into the bike this week.
Battery tests out OK. 224/220 CCA. ( I could and maybe should go with a larger CCA)
Current drain with Ignition off is 0.01 amp.
Removed the starter switch and I did not that there had been a little arcing between it and the switch housing.
Unplugged everything, and I have good clean continuity on all wires, no shorting.
Now I have NO SPARK!
I am really starting to suspect the Ign Module.
At the Solenoid, I only have 9.5volts ( on the energise wire)
Solenoid will not "engage" if I don't have the starter connected. Is this normal?
Solenoid also has an increasing tendency to stay engaged even with Ign off. I have to disconnect battery to stop it cranking.
I removed Solenoid and cleaned all contacts, looks great.
I will keep the updates coming
__________________
1986 FLHTC #86/650
Old 10-15-2009, 09:15 AM
miacycles's Avatar
miacycles miacycles is offline
The more you tell me the more I am beginning to suspect the solenoid. However the best I can do cyberly is suspect it. If it were in front of me then maybe the diagnosis would be different.
__________________
John Therrien
SPEED COSTS, HOW FAST DO YOU WANT TO GO ????
Marines may guard the gates of heaven
A job they may do well !!
But it takes the 82nd Airborne
To guard the gates of hell !!
Old 10-15-2009, 10:05 AM
Something isn't right with that solenoid. Could also be the return spring/plunger in there. I suppose that it is remotely possible that the solenoid has caused the drain, but it would have to have a short or severe carbon buildup inside the solenoid. The 9V at the coil wire of the solenoid is about typical for our era and related to The Dreaded Click.
__________________
Dr.Hess
www.drhess.net
Old 10-15-2009, 10:07 AM
1skrewsloose 1skrewsloose is offline
Everyone who has responded knows more than me, but I would add, being an 86, when you check connections, tight isn't everything, could still be corroded and feel tight. Clean all associated connections and put some dialectric grease on em, couldn't hurt. I put that stuff on every electrical connection-bulbs, switches, etc. Ounce of prevention they say.
__________________
To Ride, Shoot Straight, and Speak the Truth
Col. Jeff Cooper. RIP
Old 10-15-2009, 06:53 PM
Hang Around
Thanks for the input guys.
I have already done that, this is my 3rd "Old" bike
As far as the solenoid, It is a new solenoid, and I did pull it apart and clean it, really was not in bad condition. Also, new plunger spring.
I guess I can put the old one back in and see if that makes any difference.
I will keep you all updated!
__________________
1986 FLHTC #86/650
Old 11-03-2009, 07:54 AM
Hang Around
Default solved .... for now
After replacing the solenoid (did not fix the problem) I finally bit the bullet and returned the battery to J&P Cycles (Odyssey 680) Even though the battery tested out ok for them, they took my word and agreed to replace it.
I decided that I would not go with the Odyssey again, so instead I went with the Big Boar battery (350)
I have had it in since Saturday, and no problems at all! Bike starts right up every time (beginning to think I did not need the CR) and even my dash mount volt meter is sitting in the 14 volt range, even with the spot lights on.
I guess the battery I had was just a bad one. I know it had been suggested before, but when you spend $230 on a battery, you expect it to be good.
Any way, all I need is for the weather to stay good and get some more miles in before the snow starts to stick!
Thanks for all the input, and hopefully this will assist other riders in the future.
__________________
1986 FLHTC #86/650
Old 11-03-2009, 07:55 AM
Hang Around
Forgot to add, no more battery drain! For some reason the odyssey (even though it was only 6 months old) would not hold charge.
__________________
1986 FLHTC #86/650
Old 11-03-2009, 08:05 AM
t150vej's Avatar
t150vej t150vej is offline
Location: NC and across the Mississippi every opportunity
Don't have a clue why the drain dissapeared but who cares, the end result is the main thing. And too, when dealing with small batterys, an extra 40 - 50 CCA is a big difference, percentage-wise.
Thanks for the update Ozzie and glad to hear your ride is happy again
Old 11-03-2009, 08:59 AM
sqdealgeorge sqdealgeorge is offline
Out of curiosity Did you use a 6 amp charger on that Odyssey bat ? That bat might have been on the shelf at J&P for several years plus !
Tags
2005, breaker, charging, defective, discharge, gauge, harley, harleydavidson, main, recalls, relay, smoking, softail, stator, system, volt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
