Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Evo Classic Models
Evo Classic Models All Evo Models
Sponsored by: J&M Motorcycle Audio
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 09-23-2009, 08:46 AM
bparsel's Avatar
bparsel bparsel is offline
Hang Around
Default Intro and 60k Evo manintenance....
Just moved this from the "Touring" section to over here.
Hey fella's, just wanted to say hello, I'm sure now that Ive found my way here I will be spending a boatload of time in these forums. Ive owned a ton of bikes over the years from metrics to a couple ironheads. Ive bobbed goldwings and cafed CB750's but first time with an Evo. Anyways, my question:
Just picked up a '95 Road King with 60k on the clock. Ive searched through the forums and saw the varied opinions on rebuild mileage etc. Any specifics I should go through other than the standard fluid changes etc? The bike runs great just looking for as much dependability as possible and I'm still learning the Evo motor.
Appreciate any input. I should have compression #'s later today, where should they be? 170lbs or so? Thanks Guys!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 09-23-2009, 09:23 AM
Dr.Hess Dr.Hess is offline
I'd make sure the inner cam bearing was the replacement type. Compression numbers should be about the same, front/rear. After that, put gas in it, tires, change the oils and have a good time.
__________________
Dr.Hess
1986 FLHT: S&S carb, Andrews EV1
1987 XLH 883 Hugger (Wife's): MegaSquirt Fuel Injection
www.drhess.net
Old 09-23-2009, 09:37 AM
bparsel's Avatar
Hang Around
Thanks Dr,
I just found this thread as well
http://hdforums.com/forum/evo-classi...to-me-evo.html
which has some great info in it. The torrington bearing is the one to switch to for the Inner Cam?
Old 09-23-2009, 09:42 AM
bparsel's Avatar
Hang Around
Also, does everyone run full synthetics in the Evo motors? I always have in my other bikes and have had great success.
Old 09-23-2009, 09:44 AM
Yeah, the Torrington is what people are using. My bike came with the old style bearing, so I don't have to worry about it, but your's came with the new one that grenades. If you don't know the history, I'd pull the cam and look at it. Good time to inspect the cam and lifters for wear as well. If money's tight, then just replace the bearing if it's the junky one, put some new gaskets on and go. If you want to blow bucks, then a better cam and a new set of HD lifters too. Your bike came with the better lifters, but at 60K, they might be getting tired.
My bike doesn't like full synthetic motor oil. I run the Genuine H.D. dino oil.
__________________
Dr.Hess
www.drhess.net
Old 09-23-2009, 10:37 AM
bparsel's Avatar
Hang Around
Appreciate the info. Ill probably do the cam and lifters as well. I'm more worried about a failure, as I put on quite a few miles than the $$$. I figure $$$ spent now will payoff in the long term and I plan on holding on to this bike for awhile as it's in awesome shape other than the mileage worries. I just like o go through everything when I pick up a used bike.
Old 09-23-2009, 11:06 AM
Then get the Genuine HD lifters, sometimes called "B lifters," but they are the currently sold parts at the dealer, a mild cam of your choice, the EV27 is popular, but I like my EV1, which gives me just a tad more without going nuts, the new bearing, a shim assortment (you have to shim the new cam), oh, and the official factory shop manual (accept no substitute), and some gaskets and you should be good to go if that is a carbed bike. On an EFI, and I don't remember if they had EFI in 95, you may have to fiddle with stuff and buy tuners if you change the cam. 60K is not a lot of miles on an Evo.
__________________
Dr.Hess
www.drhess.net
Old 09-23-2009, 11:20 AM
grbrown's Avatar
grbrown grbrown is offline
I run synthetic oil in my S&S which is 'evo' style, but a recent build. I only ever ran mineral oils in the original motor, which was built before synthetics got popular. I reckon the running clearances are all too generous for modern thin stuff!
Likelyhood is your new bike has been on mineral all its life, so leave alone. It's made it this far and probably won't welcome a big change!
Welcome aboard and enjoy your bike. Its much quieter here and less fussy than over in Touring!
__________________
Graham
Harley owner since 1974, Founder & Life HOG Member.
1990 Bright Candy HiFi Blue FLHS/2008 S&S V107T, 2007 XB12R, 2003 FXDXT, MG ZT V8.
1990 FLHS/2008 S&S V107T
Old 09-23-2009, 11:49 AM
mjmangus mjmangus is offline
Senior Rider
First of all welcome. You've come to the right place. It can be a little crowded in the touring section. Just to give you a little peace of mind there are many EVO riders that are getting over 100k miles out of their motors. My son has a 94 softail with over 100k and we decided to go ahead and rebuild it now even though it still ran like a raped ape. When they came up with "ride it like you stole it" it was with him in mind. Make the checks and oil changes already reccommended and you'll be ok. BTW we run amsoil in all our machines.
__________________
2007 Softail Custom
2005 Road King Classic
1991 CHP FXRP
1942 WLA (Civilianized)
Old 09-23-2009, 01:24 PM
bparsel's Avatar
Hang Around
First of all, thank you very much for the info. I got nothing in the touring forum, except for one response telling me "You'd be better off in the EVO section"
Didnt realize the TC guys mades such a distinction.
I do have the factory manual I just havent spent much time in it yet and I know fellow riders are usually a lot more helpful than the manual. I'm switching from a Valkyrie Tourer to the RK as my primary traveling bike so there lies my concern on the motor.
I really like hearing about the 100k EVO's, makes me feel a lot better. I will run Amsoil, it has always had conventional so I'll just stick with it. Also just ordered the memphis shades Batwing fairing for the bike, so I look forward to getting that mounted up.
Dr. Hess - Thank you for the specific recommendations, huge help in taking out the guesswork for me!
Tags
1986, 1991, davidson, evo, exploded, harley, hd, lifters, touring, transmission, view
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
