Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Evo Classic Models
Evo Classic Models All Evo Models
Sponsored by: J&M Motorcycle Audio
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 05-18-2007, 08:31 PM
Sandhog's Avatar
Sandhog Sandhog is offline
Default Stumble off of idle
I have an 84 FXRP with an EV-3 cam,Screaming Eagle 40mm carb from around 1986 or so(Its been rebuilt),and Supertrapp 2/1 SS exhaust.I am having a bitch of a time getting it adjusted the way it should be.When its fully warmed up,it stumbles off idle like its cold or something.Ive tried adjusting the idle mixture,and idle speed and also the acceleratorpump cam and it IS somewhat better,but still has a bit of a "chug" or cough when ya suddenly open it up.It catches itself after a second,but that initial burp agravates the hell outta me.
Now is there something Im missing somewhere?Could it need rejetted or perhaps rebuilt again?Maybe the fuel injection on the 06 has me spoiled but it seems like it didnt do that before.Any advise will be appreciated.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 05-19-2007, 01:48 AM
pococj's Avatar
pococj pococj is online now
Default RE: Stumble off of idle
Usually a stumble off idle means a too rich mixture. But when you say it coughs or chugs, I start thinking "too lean". So I'm twiddling my thumbs here!
If it's coughing back out the carb, remove the air cleaner completely. That'll lean it out, and you can try it to see if it improves, or gets worse. That might give you an idea of what direction to go.
Might grab a handful of low speed jets on either side of what is in there now. Swap 'em out and see what happens.
Does that carb have an accelerator pump? (Showing my ignorance here, but I'm not familiar with anything newer than a Keihin butterfly carb.) If it does, try setting the adjustment so it doesn't quite squirt as much gas.
Does it stumble off idle before it is warmed up?
__________________
Brotherhood of Warriors Veterans Motorcycle Club
WFFW
BGBB Support Member
Old 05-19-2007, 10:50 AM
Hackd's Avatar
Hackd Hackd is offline
It does sound like a 'carb' issue, like was posted...You probably need to rejet the carb because of the cam/exhaust/air cleaner setup. And possibly go with a different needle or adjustable needle to make it run smooth through the transitions.
Unfortunately, I'd have to recommend that you find a shop with someone that knows how to use a dyno to tune a carb. You can 'play around' with it, maybe even 'get it right'...But you're never gonna know what's happening until it's run on a dyno and the various air/fuel mixtures are read. Trust me, it was the best $$$ I ever spent on my 93 EVO (stock CV carb, EV27, SE air cleaner, Supertrapp slipons-18 discs, dyna2000 ignition).
__________________
___________________________
76 CJ5, 5.0L Mustang Engine, T18/Dana 20, Dual ARB's, 4.56 gears, and -way too much money...
In the end...It's all Hack."
Old 05-21-2007, 10:06 PM
Sandhog's Avatar
I havent tuned up my 06 on the dyno yet.I just tuned it till it felt right with the PC and the SERT.
On my 84 fxrs I do all my own stuff sence it was new.It dosent cough back through the carb like a backfire,it just seems to sort of stumble for that second before it revs up.Like I said,I think it just needs rejetted.
The carb DOES have an accelerator pump,and ive adjusted it to where it IS somewhat better.
I think I will rebuild it again OR buy a Mikunismoothbore.
Tags
butterfly, carbs, harley, keihin, rejetting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
