Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Evo Classic Models
Evo Classic Models All Evo Models
Sponsored by: J&M Motorcycle Audio
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 04-23-2007, 01:58 PM
IronhorseMarty IronhorseMarty is offline
Default Popping out of pipes and carb
Last fall (06) I garaged the bike. It had been coughing a lot then but had times of good riding. This spring (07) I started it up (with some coaxing) and it idled fine but when I tried to ride it, it popped a lot out of the pipes and some out of the carb and I couldnt get it past 20 mph. I changed plugs, ignition module, no significant intake leak, jets are 165 and 50, mikuni hsr 42 carb, tach does bump a bit at idle, at idle throttle works fine and accelerates nicely but as soon as I put a load on the bike....bad news. Now I know why most harley owners are bald.....I'm pulling my hair out on this one. HELP. (By the way...'92 electra glide classic, 1340)
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
GottaRide
Old 04-23-2007, 02:24 PM
nfe nfe is offline
Prospect
Default RE: Popping out of pipes and carb
I'm not a tech, but I'd be changing out the fuel with some good 92 octane, and checking the timing.. That is IF you have made sure something isn't clogged in the carb..
-NFE
Old 04-23-2007, 05:21 PM
DirtyDave DirtyDave is offline
Senior Rider
Might need to replace the rubber on the intake manifold. If gas was in the carb during storage it will need to be cleaned/maybe rebuilt.
__________________
91 FXSTS
06 8-Ball
Old 04-24-2007, 09:42 AM
hard_head hard_head is offline
Senior Rider
Idles fine... but won't accept throttle under load - you have a hole/wear spot in the slide diaphram in the carb. If you want to do it yourself it isn't hard - just more hair pulling.
__________________
Give me a welder, a grinder, and a hammer - it can be fixed.
USMC
'02 - '06
Old 04-24-2007, 12:11 PM
Tucker99 Tucker99 is offline
Prospect
Yea, Yea, know about the hair pulling. I have the same carb and it runs great. Something went bad during storage. You can relieve your pain by simply buying another carb for $275. When you get to be my age the heartache an grief isn't worth it. I just spend the money and ride.
Old 04-24-2007, 03:34 PM
sjoko sjoko is offline
Hang Around
what a technician ........
...why not buying a brand new motor-cycle ?
Old 04-24-2007, 03:39 PM
Eagle_SC Eagle_SC is offline
I had a simular problem with my '89 FXRS, was running a mukini carb. But the only way to check settings and adjust was to take the carb apart. I went to a SS Super E and been running great on it ever since.
__________________
Treat the Earth well:
It was not given to you buy your parents, it was loaned to you by your children.
Old 04-24-2007, 04:29 PM
Hang Around
CV carb works great ,....when good adjusted of course ,...
mister "Hard Head" was right ,.....leak in diaphragm of vacuum piston.
Old 04-24-2007, 06:32 PM
mtnlvr mtnlvr is offline
Quote:
ORIGINAL: sjoko
Sounds like something a dealer would recommed!
__________________
Old 04-25-2007, 03:41 AM
Senior Rider
Get a six pack... or a good mixed drink... pull the carb. Popping the top off, dropping in the new slide and diaphram only takes a couple minutes. If you want to get "tuner" with it, run some 600 grit wet/dry sand paper over all the rough spots on the slide before installing it... just make sure you clean it really well with water before installing it. Then put the carb back on and presto - bike should run like new, with a little better response.
Just takes a little patience.. where the six pack comes in. You get in a tight spot, sight back and have a sip. Good luck...
Swede
__________________
USMC
'02 - '06
Tags
accerlerator, davidson, exhaust, harley, hsr, idle, mikuni, popping, rough, spitting, sportster, sputtering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
