Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Do It Yourself Help Forum > Engine Related
Engine Related Tips on spark plugs, setting engine idles speeds, exhaust, and other engine related issues.
Welcome to HDForums.com!
Welcome to HDForums.com.
Closed Thread
Thread Tools Search this Thread
Old 03-19-2006, 11:02 PM
HDF Tech HDF Tech is offline
Default EFI Heat Management
Injected Twin Cam High Temperature Idle
The 2002 and later fuel injected Twin Cam engines use a three phase heat management system to reduce engine temperature under extreme conditions. Be aware that a rider with a very hot engine may notice the affects of this three phase heat management system and incorrectly assume an idle problem exists.
Phase 1 - At approximately 320Ëš F the ECM will gradually reduce engine idle speed until the engine temperature drops or the engine reaches 800 rpm.
Phase 2 - If engine temperature reaches 338Ëš F the ECM richens the air/fuel ratio to provide additional cooling.
Phase 3 - If the engine temperature reaches 356Ëš F fuel injector pulses are interrupted. The air drawn in and expelled helps cool the engine further. Since there is no combustion it would be perceived as a misfire. This third stage will only happen when the motorcycle is stationary.
These are head temps as indicated and NOT oil temps
Reference: H-D Owner's Manual.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Closed Thread
Tags
2006, 2009, davidson, efi, engine, harley, hd, heat, idle, management, misfire, phase, softail, system, temperature
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
