Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Tech Forums > Engine/Fuel/Intake/Exhaust
Engine/Fuel/Intake/Exhaust Find answers to your engine and fuel problems here.
Sponsored by: Custom Dynamics
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 11-04-2009, 09:23 AM
jshull's Avatar
jshull jshull is offline
Prospect
Default this is what I am thinking........
I have a 09 sstreet bob, I have already installed a V&H fuel pac, V&H short shots, V&H intake, well I havew the itch for a bit more power, after some phone calls I have found out Vance and Hines only has a map for the andrews 26h cams.......I had talked myself into that but after reading for a week I see not very many are happy with that set up(except for baggers). so here is my thoughts, I can either chance the 26h and se where it puts me or I just buck up and spend a little cash here is my thoughts....
-Screaming Eagle Race Tuner
-Screaming Eagle Heavy Breather
-Screaming Eagle 204 cams
-Screaming Eagle Adj Push rods
-screaming Eagle Clutch Spring
-Vance & Hines Quite Baffles
Does that sound like a plan? I also plan to get it dyno tuned...any thing I should do differnt, does anyone have a dyno run off similar build? thanks justin
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 11-04-2009, 10:58 AM
KumaRide's Avatar
KumaRide KumaRide is offline
If your VH intake is a high flow, spending more money on a SE heavy breather will not get you anything.
If youre after more power, dump the short shots and get a 2n1. I had bss and tried the quiet baffles. They sound better but if you install cams, they will hurt performance. A 2n1 performs much better - I know this first hand... Adj push rods are not necessary, but make the cams easier to install. Which cam is another discussion and does require research and understanding how "you" ride and where "you" want your tq. Both the 26 and 204 will provide a nice performance boost as will others... With the build you are talking about, dont think you will need se clutch spring.
Race tuner is good - but if it were me, Id go for a Thundermax or TTS Master Tune Vtune so when you change your motor again you do not have to pay some one to tune it again.
__________________
Love them FB's.
06 FLSTFI
21's, Cobra HP 2n1, DFO, Spoked Smoothies
http://hdforums.com/forum/members/kumaride-albums.html
Old 11-04-2009, 11:17 AM
jshull's Avatar
Prospect
ok so riddle me this, how would cams and short shots hurt performance? the vance and hines guys told me that the cams should add 5-7 hp on the set up, I ride fairly agressive but want a streetable ride. alot of my riding is 35-65 mph. but I ride to work every day I can at 75-85 mph or so usrually. I hate the looks of 2 into 1 I just cannot bring myself to that.
Old 11-04-2009, 04:30 PM
djl's Avatar
djl djl is offline
Hang Around
Quote:
Cams won't hurt peformance as long as you match them up with the rest of the engine components. However, without getting into a windy discussion about reversion, etc., just accept the fact that if you want to run SS or any similar 2:2 exhaust system, you will leave some TQ in the dyno room compared to a 2:1 exhaust system; it is an undeniable fact that has been proven over and over again in dyno testing.
The '06 and later heads flow pretty well but flow flattens out about .500" lift. You could pull the heads, send them to BigBoyz for their $299 Street Port job and have them decked to a chamber volume of 82cc with a .030" head gasket and bolt in the Andrews 37H or 54H cams and the TTS Mastertune/Vtune or the TMax w/auto tune and you will be at or near 100TQ/100+HP. You can work out the details of chamber volume and compression with Bean or the porter of your choice.
The SERT is good stuff but not as user friendly as the two systems previously mentioned; you need to know what you are doing to tune with the SERT.
BTW, you will need the SE clutch spring and that won't hold it for long if you are an aggessive rider.
The Heavy Breather flows nicely and would be an improvement if you don't already have a high flow air filter.
Stock pushrods will be longer than I would like after having the heads decked and using the .030" head gasket but you can get the H-D Perfect fits that are .030" shorter than stock and they would work. If you go with adjustables, stay away from the newer SE tapered units (PN 18404-08); go with Andrews or S&S.
You asked about dyno runs; I just built helped a buddy build a 95", as described above with the TW37 cams; 106TQ/101HP.
Old 11-04-2009, 08:09 PM
KumaRide's Avatar
21's and 26's and 204's and 203's and others will improve performance in a 96". Others may or will not without headwork or higher compression pistons or big bore kit. And if youre dumpin that kind of cash into performance, its a little silly imo to not do it right with a 2n1.
Its not your mph speed that matters. Its the rpms in which you ride, where you shift so to speak. Just cause you go 80 mph does not mean you are reving past 3500 rpm's unless you do it in 3rd or 4th gear...
Dont get a 2n1 if you dont like them, looks does matter!!
__________________
Love them FB's.
06 FLSTFI
Old 11-04-2009, 11:11 PM
matt816's Avatar
matt816 matt816 is offline
Hang Around
There you have it! Perfect response to this question! Listen to the man amd follow what was said and youll be grinning from ear to ear for a long time!!!
__________________
You jaded ones will wither while us optimistic grow!!
Old 11-05-2009, 02:33 PM
SEDELUXE's Avatar
SEDELUXE SEDELUXE is offline
heres a nice little combo that comes to mind.
96 ci , performance baffle for rhinharts , T-Man 525 cam , Baisley superstock heads and TTS .
stock everything else 9.4-5 compression
with a fat cat it will probley do better but this bike runs great for a little out lay.
__________________
120 ci..Heads - Baisley fastest reving and cool running ..Crank - S&S ...cylinders - Axtell...pistons - Axtell...Throttle body - HP Inc ....Cam - Woods ...Exhaust - Borzilla
Sae Actual
134 tq 138 tq
142 hp 146 tq
"Doc and JD's cycle works"
Done Once Done Right
Old 11-05-2009, 05:27 PM
djl's Avatar
djl djl is offline
Hang Around
The below charts are typical of what you can expect with the 37 and the 54.
The 37 graph is your heads, cleaned up with multi angle valve job and decked for compression; no porting.
I don't recall the details of the 54 graph but heads were stock, perhaps higher than stock compression from .030" head gasket but basically a Stage I 95" build. Notice the long flat TQ curve the 54 makes.
this-is-what-i-am-thinking-95_tw54_chart.jpg  this-is-what-i-am-thinking-95_tw37.jpg
Tags
08, 96, baffles, dyna, hurt, motor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
