Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Tech Forums > Engine/Fuel/Intake/Exhaust
Engine/Fuel/Intake/Exhaust Find answers to your engine and fuel problems here.
Sponsored by: Custom Dynamics
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-26-2009, 11:17 AM
woods woods is offline
Hang Around
Default 96 inch build options
I am looking to add some power to my semi stock engine.
I already did a stage 1 to it and am looking at my options for the next step.
Not sure if I want to go all the way to a 107 build right now or do this thing in steps.
Would a cam that is intended for a big bore build work OK with the stock pistons?
I don't want to buy a cam for this engine and need to swap it out when I go up in cubic inches.
Anyone keep the same bore and just up the compression to match the higher end cam?
What kind of power difference would I see between a high compression 96 inch and a comparable 107 inch build?
I would still do headwork with either of the builds that would have new pistons.
The primary use for this engine will be touring.
Sounds like I am rambeling
Any imput would be great.
Ken
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 10-26-2009, 12:04 PM
fripple fripple is offline
I just stuck a SE-204 cam in my 09 FLTR. I got around 82hp and 99ft/lbs torque. Also alot of the touring crowd has been going with the SE-255 cam. If you don't ride above 4000 rpm, then you might consider that an option. There are lots of cam options available, it's just a matter of chosing the right one to suit your riding style. I've heard alot of good things about Woods, Andrews, and HQ cams also.
Call Don up at http://deweysheads.com/ He's a good dude to talk with. I'm sure he can steer you in the right direction.
__________________
2008 Vespa 50cc
Old 10-26-2009, 01:07 PM
Kingofcubes Kingofcubes is offline
For what your asking for I would use the Andrews 54 for a stroker. From 96 to 107 I would expect to see 8-9 more torque and horse.
__________________
01 Dyna, R&R Stage 4 head work, 98" domed CP pistons, RR615 cam, Bassani Road Rage exhaust, R&R Big Air carb, R&R ignition
SAE 116T, 116H
Old 10-26-2009, 01:19 PM
Hillsidecyclecom's Avatar
Hillsidecyclecom Hillsidecyclecom is offline
Wood 7H with a 4* advance gear for now, and then when you pull the trigger on the 107"/heads re-worked combo, pull the advance gear, and you'll really let the badger loose then!!
Old 10-26-2009, 03:09 PM
Hang Around
Thanks for all of the info.
I will probably go with one of the above cams.
I feel better getting a few more miles out of these pistons and cylinders before I swap them out. Plus that will leave me a little money for other projects for now
Old 10-26-2009, 07:12 PM
2wheeltom77 2wheeltom77 is online now
Senior Rider
I still can't decide between the 204 and 255. There are PCIII maps out there for 255s, but none for 204s that I can find. I want to run the bike for a bit before I dyno it, in case I decide to do heads as well. I've been told by reputable sources that the 255s work wonderful in a stage 1 96" motor. Personally I like the sound of the 204s better, and they seem to make about the same numbers. The trick is finding a deal on them, as Harley quoted my $300 for the 204s.
__________________
2008 FXSTC dark blue pearl
V&H straight shot slip ons
Big Sucker
PCIII
...08FXSTC...
Old 10-26-2009, 08:04 PM
SEDELUXE's Avatar
SEDELUXE SEDELUXE is offline
why dont you get a TTS and concentrate on tuning the bike correctly befor upping the power ......
__________________
120 ci..Heads - Baisley fastest reving and cool running ..Crank - S&S ...cylinders - Axtell...pistons - Axtell...Throttle body - HP Inc ....Cam - Woods ...Exhaust - Borzilla
Sae Actual
134 tq 138 tq
142 hp 146 tq
"Doc and JD's cycle works"
Done Once Done Right
Old 10-26-2009, 09:30 PM
2wheel, check the for sale touring section. I saw someone had SE-204's new in box for sale.
__________________
2008 Vespa 50cc
Old 10-27-2009, 06:01 PM
SEDELUXE's Avatar
heeres a 103 build that will knock your socks off
__________________
Sae Actual
134 tq 138 tq
142 hp 146 tq
Old 10-27-2009, 06:35 PM
George,
Don't forget our carbed 103" that Dave tuned, that showed almost 120/120, SAE, after 4 years of being flogged, before he tuned it.
Scott
Tags
107, 255, 95, 96, bore, build, cam, cams, cylinders, harley, head, inch, motor, sale, stock, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
