Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Tech Forums > Engine/Fuel/Intake/Exhaust
Engine/Fuel/Intake/Exhaust Find answers to your engine and fuel problems here.
Sponsored by: Custom Dynamics
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
  #31
Old 10-31-2009, 11:45 AM
Kingofcubes Kingofcubes is offline
Quote:
Originally Posted by NWMT View Post
Really, i thought 5k would be plenty for going to 107ci. I will have to do some more checking, what ever the cost, it has to be done. So it is what it is.
Some of you guys sound like you own your own shops, i like this forum already. Heres a stupid question: Any body have a rough estimate on parts for going to 107 from a 96? I would expect labor to be nasty, but i plan on doing alot of the work myself and have a friend with a local shop who will help with the rest.
I now have all winter to getrdone, woke up with 3inches snow at the house this morning. ftw..
You can get the pistons and bore job done for around $450.00. Heads will range from $300.00 for the clean up hand ported to $850.00 for cnc ported. $1,420.00 for compression released, welded and cnc ported heads (like the heads I used on the shop Dyna). Many people who ride the shop bikes mention how quick the torque comes up with these smaller port heads. The other shop dyna has the R&R stage 5 castings which are $1,450.00 but require a larger TB. The torque comes on 600 to 800 rpm's later than the stage 4's but there is so much more of it you can't tell.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
01 Dyna, R&R Stage 4 head work, 98" domed CP pistons, RR615 cam, Bassani Road Rage exhaust, R&R Big Air carb, R&R ignition
SAE 116T, 116H
  #32
Old 10-31-2009, 12:43 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com Hillsidecycle.com is offline
Sponsor
The 107" kits we offer, with our proprietary Stage III Heads, with releases, proprietary Wiesco piston/Cometic gasket kit( cylinders bored,rings gapped/installed) our proprietary pushrods manufactured by Smiths, either a Wood 7H, or Wood 8 cam for '07-up T/C's, with new bearings, right down to include the NGK plug we use, pre-gapped, is only 2375.00!!!
The quick, broad, power delivery, ease of installation, easy tune, and smooth running is what seperates these from most others.
Coming in the VERY near future is our HMM .570 Express cam. Designed to work at 10.4-10.7 cr, and without headwork, our piston kits yield 10.5 under the OE chamber. That "budget build" kit will be 1229.00. On paper, it shows to be a very promising combination indeed, as Mike Peterson, GM, of Andrews Products aggrees.
Scott
__________________
PALMER BROS.
HILLSIDE MOTORCYCLE & MACHINE, INC.
5225 S. MAIN ST., MUNNSVILLE, N.Y. 13409
315-495-6650
www.hillsidecycle.com or .net
"Repairing Broken Torque Curves For Over 28 Years."
Land Speed Record Power
  #33
Old 10-31-2009, 03:40 PM
mikedmeyer mikedmeyer is offline
Prospect
Quote:
Originally Posted by SEDELUXE View Post
If you send me your e-mail address i will send you the dyno sheets to a build Dave just did.
the build specs are
96 ci
stock pistons
stock cylinders
stock t/b
tbw
TTS
Baisley heads
9.4 compression
T-Mans 525 cam
106 hp/tq sae if i remember correctly
It does not get any better then that
for a minimun out lay of cash and the reliability of stock.
Sounds like a great, inexpensive combo. But what is "tbw?"
__________________
Chrome don't get you home.
  #34
Old 10-31-2009, 04:42 PM
SEDELUXE's Avatar
SEDELUXE SEDELUXE is online now
Quote:
throttle by wire 08, 09-10 bikes have it
__________________
120 ci..Heads - Baisley fastest reving and cool running ..Crank - S&S ...cylinders - Axtell...pistons - Axtell...Throttle body - HP Inc ....Cam - Woods ...Exhaust - Borzilla
Sae Actual
134 tq 138 tq
142 hp 146 tq
"Doc and JD's cycle works"
Done Once Done Right
  #35
Old 10-31-2009, 06:44 PM
SEDELUXE's Avatar
heres that dyno sheet.
also one with standard baffle and the performance baffle
__________________
Sae Actual
134 tq 138 tq
142 hp 146 tq
  #36
Old 11-01-2009, 05:51 PM
Prospect
the build specs are
96 ci
stock pistons
stock cylinders
stock t/b
tbw
TTS
Baisley heads
9.4 compression
T-Mans 525 cam
Which Bailey's head is this? SuperStock, ProStreet...?
__________________
  #37
Old 11-01-2009, 07:30 PM
SEDELUXE's Avatar
\super stock
__________________
Sae Actual
134 tq 138 tq
142 hp 146 tq
  #38
Old 11-02-2009, 02:31 AM
paul s's Avatar
paul s paul s is offline
1998 chevrolet camaro
\super stock
Are the reliefs on the stock pistons clear for the larger valves? I noticed a few people on these forums grinding them larger.
  #39
Old 11-02-2009, 07:44 AM
Sponsor
Paul,
The OE pistons need to had the valve reliefs moved/enlarged.
We use a piston fixture in one of our 3, vertical milling machines, and with a 2" cutter, at the OE valve angle, establish that work.
Scott
__________________
PALMER BROS.
315-495-6650
Tags
113, 113ci, 96, cam, ci, davidson, dyna, eagle, engine, harley, hd, kit, kits, screaming, softwail, stage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
