GO BIG__ONCE!! Then enjoy the ride. You won't be disappointed. The guys on this forum know the combos that work together and that is one of the most important issues when considering a build.
__________________
2003 FLHRCI, 117" built & dyno-tuned by Steve @ GMR, Axtell's cyls. & piston kit, 10.5:1 CR, R&R 5 pc crank, Timken conversion, R&R Stage V cast heads w/comp. releases, R&R roller rockers, SE billet camplate & high volume oil pump w/Latus spring, 615/585 gear drive sticks, HPI 51mm T/B, stock injectors, Rivera Pro clutch, D&D Fat Cat w/ big bore perf. baffle, Zippers big A/C, stock 3.15 gearing, ultra cord drive belt
124HP-139TQ SAE TTS MasterTune
Just got back from my dealer (Rochester HD, MN). The service guy has done a lot of builds. Gave me a price to go the the 103 by boring stock cylinders, new cast pistons, manual CRs, mill heads .020-.030, SE 255 cams and gasket kit, Torrington bearings, tweak HD map, reuse push rods. Without tax, $1150-$1200 installed. Have asked them to see if they have a used set of SE 255's around which could save another $100. (going with the standard KIT price would have run around $1850)
He knows what I'm looking for, low-mid range tq, decent MPG, smoot running and I have high confidence in him. Not looking for a hot-rod, but should see around 15 gain in both tq and hp. Going to take the bike in November, then get ansy as I will have to wait until the snow leaves MN to ride :-(
Current: 07 Ultra, SE A/C, old SE slip ons, SERT, 33K miles. This will be my first performance upgrade other than the basic stage one. Getting very excited.
__________________
A MN Patriot Guard Rider - because I care!
07 Patriot Edition Ultra Classic – US Marine Corps
SE 255 cams, SE A/C, SE II Slip-ons, SERT - 82HP/97TQ
Sounds like a good price for the build. I'm awfully tempted to see if the Lakeville, MN I got mine from will do something similar over the winter. Especially as that doesn't void the warranty...
If it weren't for Warranty concerns I'd be all for bumping up to 107
talk to them and see what type of deal you can work out with the dealer.
if you get some one who knows what they r doing and make sure everything is set up correctly u will end up with a solid build.
ask themto cc the heads
make sure they are even
make sure piston are at zero deck . they are not below the top of the cylinder when piston is at tdc.
ccp is also correct .
also make sure they custom map or tune the bike
you can get a solid runner if they pay attention to details and not just slap it together
__________________
120 ci..Heads - Baisley fastest reving and cool running ..Crank - S&S ...cylinders - Axtell...pistons - Axtell...Throttle body - HP Inc ....Cam - Woods ...Exhaust - Borzilla
Sae Actual
134 tq 138 tq
142 hp 146 tq
"Doc and JD's cycle works"
Done Once Done Right
Here is my suggestion for the money, build the 107, have the heads ported, nothing crazy $400 max, use an Andrews 54 cam, a 0.30 thick head gasket, and your done.
What goes wrong with so many other builds is you don't factor all the extra cost in for push rods, lifters, gear drives etc.
The above build will net you between 105-110 HP and 115-120 TQ.
This will be a fun bike to drive with torque where you drive it.
A D&D exhaust is one of the best bangs for the buck.
Look up Revolution Cycle Performance on the net. They put this kit together for $1100.
Add a Thundermax ECU with auto tune and your done for reasonable money.
