Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Tech Forums > Engine/Fuel/Intake/Exhaust
Engine/Fuel/Intake/Exhaust Find answers to your engine and fuel problems here.
Sponsored by: Custom Dynamics
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-30-2009, 04:38 PM
prodrag1320's Avatar
prodrag1320 prodrag1320 is offline
Prospect
ide go with the geardrive,or just leave the stock stuff in there and check the tensioners from time to time (once every 7 or 8K),as far as being bullitproof,the new SE set up aint any better than what your running now
kirby
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 10-30-2009, 05:48 PM
rthomp159's Avatar
rthomp159 rthomp159 is offline
Gears are awesome, but I'd be hesitant to use them on a stock crank. I'm sure one of the builders will say it's fine, and I defer to their experience, but I'd be iffy about it. Regardless, you should check your runout and deal with that before you do anything. As I said in another thread, my runout was .005, and I had scoring on my oil pump at less than 20,000 miles.
__________________
'05 Vivid Black Night Train
Lots 'o black
103 by Dave at JD's
116.70/116.01 SAE
Old 10-30-2009, 07:54 PM
neonhomer's Avatar
neonhomer neonhomer is offline
Senior Rider
Send a message via Yahoo to neonhomer
All this discussion, and it doesn't help me much... I am still as confused as I was when I started this thread.
I would like to go with gears to eliminate the need for tensioners, but I think it might cost more to do gears than just replacing the stock tensioners & new cams.
__________________
NeonHomer
2004 Road King Police FLHP/I *Dynojet PC3 USB * Screamin' Eagle Stage 1 A/C
Old 10-31-2009, 07:30 AM
ryanl's Avatar
ryanl ryanl is offline
Prospect
andrews unit runs around $400
__________________
<a href=http://i274.photobucket.com/albums/jj275/ryanlisewski/IMG_1156.jpg target=_blank>http://i274.photobucket.com/albums/j...i/IMG_1156.jpg</a>
^Currently For Sale^
Old 10-31-2009, 05:29 PM
dgvnk's Avatar
dgvnk dgvnk is offline
Hang Around
You might give John Wadsworth a call at Flying W Performance.He sells a kit to convert to the hydraulic tensioners.He also sells Andrews Cams,SE Adj.Pushrods and Harley B Lifters.I put one of his kits in my 2006 Night Train,during instillation I had a couple of questions,called John he took the time to answer my ?'s and help me out.He is a good guy and sells a good product.
__________________
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden"><input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden"><input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden"><input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old 11-01-2009, 12:12 PM
poppadeuce poppadeuce is offline
Hang Around
Quote:
Originally Posted by JR-Boston View Post
If I go with just the HD chain tensioner upgrade kit, and put the old cams back in, do I need to replace the pushrods?
I'm thinking the reason we cut the old pushrods out and put in new EZ Adjust pushrods is to accommodate a new cam set's greater lift.
Am I on the right track here?
JR
Cutting your old rods and putting in adjustables eleminates removing your top end.
Old 11-01-2009, 12:22 PM
neonhomer's Avatar
Senior Rider
I actually WANT to pull my top end apart because I believe there is something not right up there.
__________________
NeonHomer
Old 11-01-2009, 12:30 PM
caper's Avatar
caper caper is offline
Hang Around
If you want to take the top off and the cam you're putting in has the same base circle diameter as the stock cams, then the sock rods can be reused.
Old 11-01-2009, 12:37 PM
Faast Ed Faast Ed is offline
If you run gears, you are no safer than if you stay with tesioners (unless you weld your crank).
Why? If your crank slips a few thou, you will be redoing your bottom end. I have witnessed this first hand (not hearsay).
My Andrews cam has a .020 smaller base circle, which was great for me to reuse my stock pushrods with a thinner head gasket. Win/win.
Keep in mind, your lifters allow for a little variance there.
__________________
08 Heritage, 103", 54's, HPI 51mm,
WFO Larry Grooved heads 10.4:1,
1.90 intake & stock exhaust valves,
D&D Fatcat, SERT,
SE Compensator, Doherty plate w/Zippers A/C
104.79HP/114.25TQ SAE DJ250i
Old 11-01-2009, 01:12 PM
neonhomer's Avatar
Senior Rider
Quote:
I just got an email back from him. $500 for the conversion kit, and $259 for the cams. Add $95 for new B lifters and $145 for adjustable pushrods.
This doesn't include all the stuff I would need to pull the rocker boxes...
__________________
NeonHomer
Tags
bad, conversion, drive, drives, gear, good, harley, herko, kit, products, tensioner
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
