Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Tech Forums > Engine/Fuel/Intake/Exhaust
Engine/Fuel/Intake/Exhaust Find answers to your engine and fuel problems here.
Sponsored by: Custom Dynamics
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 09-12-2009, 10:17 PM
Shovelhead Bob Shovelhead Bob is offline
HDF Tech Moderator
Exclamation Good Scoop.... "New Fuel"
Over the past 24 months, modern day gasoline has undergone numerous changes.
Gone are the days of knowing that your Premium grade gasoline was in a refinery just a week or so ago, and you were paying $1.95 a gallon... and Stoich was 14.7 (Stoich is the optimum fuel-air mix for no/light load operation)...
Nowadays, our fuel is enhanced with, what they say is no more than 10% Ethanol, not to mention all the other additives (Detergents, inhibitors, etc...), and it has been sitting in the underground storage tanks for months or a year, untouched and getting stale.
And yet, that is for year old gasoline that is at best, 14.3 stoich... (ethanol enhancement requires that your bike be reprogrammed/rejetted fatter).....
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 09-12-2009, 11:27 PM
paul s's Avatar
paul s paul s is online now
1998 chevrolet camaro
Shouldn't my auto tune take care of that?
Old 09-15-2009, 12:41 AM
mgmmgm's Avatar
mgmmgm mgmmgm is offline
Senior Rider
Angry the fuel
I am not a gasoline wizard, but since this ethanol #$#@ stuff came out, my bike don't run as well. I think it's cr#p.
__________________
07 Fatboy: 103 c.i. D&D Fat Cat, Red Shift 575 Cams,Baisley super stock heads and roller rockers,AIM clutch, Feuling oil pump & lifters,S&S springs,SE push rods, Amsoil
Thunder Max, Doherty PowerPACC
* http://markmomb.blogspot.com
Old 09-27-2009, 04:42 PM
rbabos rbabos is offline
Quote:
Only if the map is set to a richer value. If for example the map is set to 13.5, auto tune works to retain this with varying operating conditions. It won't branch off on its' own to come up with different afrs on it's own. With ethenol maps need to be slightly richer with 10% and up according to the amount. Then autotune will keep it in this range.
I for one don't have a problem with ethenol. Match the afrs accordingly, increase the compression and the same if not more power can be had. I guess the only down side is more fuel needs to be burned to get the same hp. The other down side is ethenol sucks moisture out of the air, which in turn mixes with the gas. Too much and it could dump into the system an cause problems. Present efi venting systems eliminate most of the problem but I still try to keep a full tank if the bike sits for a while. Since there is no other suitable fuel to run, knowing the negatives and how to compensate will make life easier when using it. If you feel the engine runs like crap using it, the afrs need to be richened and the timing needs to be advanced some.
Ron
__________________
07 Softail Custom
V&H BSS
Screaming Eagle Heavy Breather
Screaming Eagle Big Twin Compensator
Tmax
Harley Blade 41681-07 wheel
The puppy lasted until fall. Now in teardown mode for new build
Old 09-29-2009, 10:15 PM
1BadSally's Avatar
1BadSally 1BadSally is offline
Hang Around
For a new guy like my self this is way over my head. So your saying for my bike to sufficiently use the ethenol I should install a programmer and have it tuned as you say above?
__________________
08 Sucker Punch Sally's 66 Bobber
Old 09-30-2009, 05:34 PM
neonhomer's Avatar
neonhomer neonhomer is offline
Senior Rider
Send a message via Yahoo to neonhomer
Too bad there is not a way to buy gas, and then separate the ethanol from the gas.
__________________
NeonHomer
2004 Road King Police FLHP/I *Dynojet PC3 USB * Screamin' Eagle Stage 1 A/C
Old 09-30-2009, 07:32 PM
HDF Tech Moderator
Any bike running this "New Fuel" needs to be rejetted, reprogrammed, etc... as the Ethanol has a completely different "Stoich".... As stated in the initial posting....
Gasoline isn't gasoline anymore.... it's blended crap to pay for roads and pad oil company exec's wallets...
Old 10-03-2009, 06:14 PM
Quote:
Removing the ethenol is easy. Add water to the gas and the water and ethenol blend together. Then pour the gas off the top of the water. Problem is, you now have a lot less octain since ethenol is part of the octain agent in modern fuels. In the end, tuning it for ethenol blends will be easier than going through all this. It's here to stay with more % coming in the future.
Ron
__________________
07 Softail Custom
V&H BSS
Tmax
Old 10-05-2009, 08:01 PM
HarleyPartsGarage HarleyPartsGarage is offline
Hang Around
Default Gas in California
Hello, I have a 2006 FLHX TC88, and it is very sensitive to fuel. My riding buddy has a 2007 FLSTF and his bike reacts exactly like mine in regard to fuel (Quality?). When I get a tank of "bad" gas it is coughy and performance is noticeably off. My buddy actually took his bike into the dealer once because it was running so poorly...bad fuel! Is this because it is "Old Gas" ? Some gas stations I have to avoid because you frequently end up with this kind of gas. Is the gas in California formulated differently?
Old 10-05-2009, 08:13 PM
Faast Ed Faast Ed is online now
My bike didn't like any of the gas available within 100 miles of Sturgis.
I am very spoiled on the good ol' BP 93 octane that is common in my region.
(I know, it won't be there forever).
__________________
08 Heritage, 103", 54's, HPI 51mm,
WFO Larry Grooved heads 10.4:1,
1.90 intake & stock exhaust valves,
D&D Fatcat, SERT,
SE Compensator, Doherty plate w/Zippers A/C
104.79HP/114.25TQ SAE DJ250i
Tags
air, baisley, bob, chrome, cleaner, custom, efi, fat, harley, hd, heads, intake, maps, scoop, scooped, superstock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
