Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Tech Forums > Engine/Fuel/Intake/Exhaust
Engine/Fuel/Intake/Exhaust Find answers to your engine and fuel problems here.
Sponsored by: Custom Dynamics
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
  #71
Old 10-18-2009, 12:07 AM
BigDaddyMike's Avatar
BigDaddyMike BigDaddyMike is online now
My 09 FLTR started ticking recently. Just before 3000 miles. Had oil changed recently and Indy said he 'heard ' it also. Recommended taking to dealer to listen/check it out. I'll let you know what they say. This is definitely an engine noise, from the front jug, easily heard at idle and higher rpms with bike in neutral and stationary. Doesn't seem to be any worse or better riding or warm or cold, it's just 'there' and you're right Chief...it sucks!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
05 FLHRSI/95ci/ SOLD!
09 FLTR Red Hot Denim/HOME!
  #72
Old 10-26-2009, 11:31 PM
OK so my bike ticks too. Best as I can recall it started at about 1000 miles when I changed oils and put Redline in. I have ALWAYS run Redline products aBUT never had a 96 inch engine. So I was going to bring it to the dealer and let them listen/diagnose and I thought I would change the oil so I could say I was running HD Oil, lest they give me that line of crap...Guess what...put HD 20/50 in, new filter, fired her up NO TICKING..I am amazed...could it be? Couldn't ride but ran it for about 20 minutes til up to operating temp. Will ride timorrow and see. I'll still have it looked at but maybe this is the simple fix....What do I know?
__________________
  #73
Old 11-11-2009, 12:15 AM
Sidecar Cycles's Avatar
Sidecar Cycles Sidecar Cycles is offline
Hang Around
2009 Harley Davidson FLTR
My Garage
Default Run around...
May I suggest going back to the beginning! I know your frustrated by the whole oil thing! BUT, if I may ask...
How many oil changes did you go through with each type... If you went from one to another at each oil change interval you are doing yourself an injustice. It takes at least two / three intervals to remove the remnants of the previous oil. When you change your oil you are completely removing the oil in the tank (under tranny), as well as the filter... that's it!, Left in there is the oil in the sump (crankcase), about 6 ounces... because its a dry sump, there is a drain screw at the bottom of the crank for removing this oil, to help determine if your oil pump is working correctly. These engines are dry sump and if the pump starts to fail, oil will build up in the crankcase where the flywheel is spinning, the excess oil will impede rotation of the flywheel thereby robbing you of HP! Anyway... also left in there is the oil in the rocker boxes, lifters, oil lines, oil pump, cam housing and oil galley's! So before this sends you off the deep end, go back to dino oil for at least three intervals (sorry, patience will be required). I've done this a number of times with noise complaints and with good results... there is no question about the benefits of Sync... less wear and lower operating temps, but who wants to put up with the noise, not to mention the development of oil leaks at the rocker boxes, the head gaskets and even along the joint between the motor and tranny... shows up as an ugly gray graphite looking mess that's difficult to remove... your local dealer will, believe it or not, tell you its normal... it is not! You can bet if they didn't sell a Sync oil themselves, the finger would be pointed BIG TIME. The catch with Sync... its so thin, that it gets in everywhere. That thin characteristic is what causes these engines to get noisier... that's why it would be to your advantage to switch back, permanently, to those larger dino molecules! It will reduce the noise significantly, allowing you to get on with determining the real problem!
Having said that, I would highly recommend installing a set of adjustable push-rods. The reason being... the assembly of these engines is... assembly line, not balanced or blue printed, "HELL NO"!!! In choosing a set of adjustable push rods, you want to go with a higher thread count (fine thread) for two reasons, more strength and finer adjustment... trust me, after installing a set, you'll know what I mean... its all in locking that jam nut while holding two other wrenches after you've found the sweet spot!
Hint... if you ever want to narrow down a problem with a part, check out the Screaming Eagle parts catalog, case in point... Screamin' Eagle® Perfect Fit Pushrods. W h a t a j o k e!
Copy the following link
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Another prime example... Screaming Eagle Compensator sprocket. They introduced it in the '06 & up Dyna's and '07 & up everything else. The spring in the original isn't strong enough... rather than admit it, or better still eat it $$$, they simply corrected the problem and called it a Screaming Eagle Performance part!! NICE...
PS
How hot is your bike running... if you've gotten this far and would like more info on this, let me know!!
Tags
adjust, clutchstack, cylinder, davidson, exhaust, front, harley, height, lifters, limiters, mobil, pipes, shovelhead, ss, ticking, valves
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
