Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Tech Forums > Engine/Fuel/Intake/Exhaust
Engine/Fuel/Intake/Exhaust Find answers to your engine and fuel problems here.
Sponsored by: Custom Dynamics
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 07-26-2009, 12:20 AM
88racing 88racing is offline
Prospect
Question Weird isolated rpm vibration?
On our recent 1400 mile round trip my bike developed a strang isolated vibration.
I have a 07 flhx 103 stage 1 with hd race tuner.
I also run the KW double back headers into VH basic slip ons and a heavy breather air intake.
Running up through the gears the vibration happens in every gear.
The vibration starts at 2800rpm and stops after 3100rpm.
When I got home from the trip tried it in nuetral and still does it. With the exception of when in nuetral the rear cylinder is spitting and popping up to 3100rpm.
Any thoughts?
Talked to the stealership and they said it might be a motor stabilizer out of adjustment.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 07-26-2009, 12:59 AM
BAGGERDSM's Avatar
BAGGERDSM BAGGERDSM is offline
Did you check the motor mount condition?
The rear cyl shouldnt be spittin and popping at all. Do a CCP test on the front/rear cyl..
__________________
Hillside Cycle 117 build
Hillside Custom heads~Axtell 117 cyl+pistons~Mikuni HSR48 with "D" manifold~Wood TW9BG cams~DTT~Rivera ProClutch w/VPC~Boarzilla~S+S Rockers~etc......
Built by me, Machine work/porting by Hillside Cycle, Tuned by Jd's Cycle Works...
<a href=http://i78.photobucket.com/albums/j91/baggerdsm/danny3018-1-1.jpg target=_blank>http://i78.photobucket.com/albums/j9...ny3018-1-1.jpg</a>
Old 07-26-2009, 02:51 AM
Prospect
Ok so how are the mounts or stablizers supposed to look like if worn or damaged?
Time to break out compression test kit? For the rear?
I will see how that goes.
Old 07-26-2009, 06:45 PM
Old Gunny Old Gunny is offline
Do both so you can compare.
I had a fuel injector leak thru once, that was a wonderful adventure. And at first sent me off to the wrong direction to fix. I though the ECM had gone crazy.
I guess one could plug up just as well. That would give that cilender fits I bet.
Old 07-30-2009, 08:36 AM
Prospect
I don't know if I did the compression test right?
Tested each cylinder for 5 revs.
Rear started at 150 and ended up at 190.
Front started at 120 and ended up at 155.
Did the check with it being cold and slightly warm with same results.
Couuldnt find any numbers in service manual to compare to or a procedure for the hd.
Old 07-31-2009, 12:32 AM
02flh 02flh is offline
Prospect
engine warm throttle wide open. Front looks weak. both should be near the same. I belive 140psi is normal and that would change with cam timming and cyl condition. but with throttle wide open. That weak front cyl you could but some oil in the front cyl and see if the Psi goes up and if it dose it looks like a cyl scuff. Weird but some times a scuff will go away with use, I would double chck my mixture and timming to make sure I am not cooking the engine at cruise speed. crank? front cams slow timming? curious minds want to know.
Old 07-31-2009, 07:30 AM
Prospect
Okay I will run the compression check again tonight.
Kind of a shame the bike only has 7K on it and already doing things that should happen at 25K. But with the 103 mass produced kit that I had the dealer put in the bike. I knew there would be problems sooner or later. If I can't find the problem I think its time to go bigger and get it retuned by a good shop. Let you know the results at the 2nd attempt.
Old 07-31-2009, 08:44 AM
rbabos rbabos is online now
For diagnostic purposes a leak down test will give better results. Do this with a hot engine since nobody drives around with a cold engine. It will pinpoint where the leaks are like valves, cyls. Standard compression tests are only good to determine cold cranking compression and differences between the two. Your differences are too much to have a smooth running engine. A leak down test will tell you where the problem is, with no guessing. There maybe an rpm where this roughness and mounts won't agree with each other, which is likely what you are feeling. Rubber mounts have a limited range of function to maintain smoothness.
Ron
__________________
07 Softail Custom
V&H BSS
Screaming Eagle Heavy Breather
Screaming Eagle Big Twin Compensator
Tmax
Harley Blade 41681-07 wheel
The puppy lasted until fall. Now in teardown mode for new build
Old 07-31-2009, 10:00 AM
matrix5's Avatar
matrix5 matrix5 is offline
Just throwing this out there (may be a long shot), but I had a similar issue with a vibration between 2600 and 2800 rpm. Turned out to be my highway pegs. I had moved them up the engine guard a bit and they just didn't like being there in that rpm range. Since that is where I ride most of the time, the pegs got moved back down.
Just a thought if you have pegs.... FWIW.
Old 07-31-2009, 12:57 PM
Prospect
I will take my pegs off and see if that makes a difference also. I had put them on for the trip and had never used them before.
Tags
cam, cams, compression, cranking, dose, double, engine, engines, harley, harleydavidson, make, mikuni, rear, rpm, slow, test, twin, vibration, weird
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
