Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Tech Forums > Engine/Fuel/Intake/Exhaust
Engine/Fuel/Intake/Exhaust Find answers to your engine and fuel problems here.
Sponsored by: Custom Dynamics
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 04-08-2009, 07:06 PM
sam01rk sam01rk is offline
Hang Around
Default stalling when hot
I bought a 2001 RK this spring and it seemed to run great but on two different days a few weeks apart it was having a problem: when I would stop at a light the motor would hesitate or stall altogether. No problems at speed. These two days happened to be the two warmest days of the spring so far, temps about 70. the second time I had also just filled up with 87 octane gas from a grocery store (might be crap gas). I always used to put 87 in my evo softails and never had problems. Could my issue be from gas or is it for sure some problem with the EFI? Now it's cool again so I can't really test any theories.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 04-08-2009, 07:55 PM
rbabos rbabos is offline
Maybe a good cleaning of the iac port with tb cleaner will fix it.
Ron
__________________
07 Softail Custom
V&H BSS
Screaming Eagle Heavy Breather
Screaming Eagle Big Twin Compensator
Tmax
Harley Blade 41681-07 wheel
The puppy lasted until fall. Now in teardown mode for new build
Old 04-08-2009, 10:51 PM
Hang Around
Thanks Where is the IAC port? My clymer book shows an IAC port on the delphi but not the MM
Old 04-09-2009, 05:54 PM
Honestly, Ive never seen the MM tb. Look for any suspicious holes and hose them out with cleaner. The port will likely be close to where the breather bolts on and at the top. If you find the iac motor, it will point to the port location. It can be heard when the key is turn on and off as it sets itself.
Ron
__________________
07 Softail Custom
V&H BSS
Tmax
Old 04-20-2009, 06:41 PM
Hang Around
Default still need help, please. Stalling on warm days
OK. I need help thinking this through. here's what I know:
1) it happens only on warm days; on cool days (less than 60 F) I can drive however, wherever without any problems.
2) it can happen even when the engine is not warm, like leaving work after the bike has been parked for several hours
3) it never happens at speed
4) it happens when I am stopping or leaving from a stop
5) lights and instruments stay on; check engine light is lit for about 5 seconds.
6) idle is normal once the motor warms up, even immediately beofre and after the stall.
7) bike starts right up after a stall, though the fuel pump sounds like it cycles twice sometimes
8) on cold starts, the idle is really low for about 30 seconds, dies sometimes (like on the first start of the morning), but if I give it some gas to warm up, it levels out quickly at 1000 rpms.
9) no codes are stored when I check using the hold-odometer-button-then- turn-ignition-on method
Right now I am thinking of trying, in this order:
1) clean my IAC valve
2) have coils and ignition checked
3) fuel filter
4) fuel pump
5) Intake air temp sensor
What would you guys do? thanks in advance for input
Old 04-20-2009, 08:33 PM
SEDELUXE's Avatar
SEDELUXE SEDELUXE is offline
wasnt there a problem with a leaky hose in the tank or did it have holes in it???
something about the line in the tank i cannot remember but there is a line in th etakn going from the pump to the fuel outlet. i beleive sopme guys were getting holes in that line causing it to sputter and stall.
__________________
120 ci..Heads - Baisley fastest reving and cool running ..Crank - S&S ...cylinders - Axtell...pistons - Axtell...Throttle body - HP Inc ....Cam - Woods ...Exhaust - Borzilla
Sae Actual
134 tq 138 tq
142 hp 146 tq
"Doc and JD's cycle works"
Done Once Done Right
Old 04-20-2009, 09:44 PM
The most likely candidate would still be the idle air control or whatever it's called for the MM. Apparently it has a different name but much the same function. That much I did find out. It's called an isc (step motor) and are somewhat problematic. The fact it's not setting correctly for cold start leads me in that direction again, since you can make it run steady with the throttle. If you have no high load issues, ignition is not likely the problem. Same with fuel . If it will pound through the gears and maintain high rpms, both flow and pressure is somewhat normal. A fuel pressure test will confirm if there is a borderline problem, or intermittent. Intake air sensor would likely only change the afrs richer, but not enough to cause your problem. Disconnecting it makes the engine thinks it's cold. I would also check any wire connections to the tb for corrosion and bad contacts.
Ron
__________________
07 Softail Custom
V&H BSS
Tmax
Old 04-20-2009, 09:55 PM
rk2001hd rk2001hd is offline
Hang Around
I am having the same problem and I have replaced the fuel pump, fuel lines, fuel filter, crank sensor, speed sensor, engine temp sensor and tilt sensor. I have checked every wire for shorts and replaced the battery. I have had the bike to our local dealer three times and they can not find a problem. This has been going on for about a year and a half and it still is not running correctly. If you find out the problem be sure to let me know! My email is rk2001hd@yahoo.com
Old 04-20-2009, 10:50 PM
Hang Around
Thanks very much for the input. I will target the ISC next and let you know.
Old 05-07-2009, 11:43 PM
Hang Around
Default Yep
It was the ISC. Rusted up. thanks for the ideas. Cheers
Tags
2007, davidson, efi, fuel, harley, hot, iac, idle, injection, low, softail, stall, stalling, stop, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
