Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Tech Forums > Engine/Fuel/Intake/Exhaust
Engine/Fuel/Intake/Exhaust Find answers to your engine and fuel problems here.
Sponsored by: Custom Dynamics
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 03-04-2009, 03:12 PM
Hillsidecyclecom's Avatar
Hillsidecyclecom Hillsidecyclecom is offline
I'll chime in and answer.
The TTS is the new tuning device that was designed by Steve Cole. He designed the S/E Race Tuner for Harley.
Has more flexibility for the tuner.
The spring, if not mistaken, is and pressure relief valve spring to enhance oil pressure.
Scott
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 03-04-2009, 08:34 PM
Old Gunny Old Gunny is offline
The se 258 is going to move your power band up.
The 6hg is very close to the 7H I have, a little higher lift. All other spects same. It will have all the torque you can want. My motor makes power and will pull 6th. gear from 1500 RPM on. Strong cam but probably runs out 5500 RPM or a little less. I have never gone higher that 5000 cause I like riding not walking.
You want the 6H I figure a little more torque that the 7H.
Old 03-04-2009, 11:11 PM
SEDELUXE's Avatar
SEDELUXE SEDELUXE is offline
scott and gunny are correct.
TTS is a far superior tuning device then anything on the market.
the 6hg will get you more tq and hp right off the bat then the 258 also it will out power the 258 every where on the rpm range.
remember with the 6hg you will need roller rockers talk to Dan baisley about them also .
tell Dan Baisley dave from JD's told you to call. or just call Dave he will give you a discount on the parts i know he gives forum members a a discount.
G
__________________
120 ci..Heads - Baisley fastest reving and cool running ..Crank - S&S ...cylinders - Axtell...pistons - Axtell...Throttle body - HP Inc ....Cam - Woods ...Exhaust - Borzilla
Sae Actual
134 tq 138 tq
142 hp 146 tq
"Doc and JD's cycle works"
Done Once Done Right
Old 03-04-2009, 11:43 PM
mgmmgm's Avatar
mgmmgm mgmmgm is offline
Senior Rider
Currently having my 96 built to 103. Am having Dan Baisley do street heads for it, and will have roller rockers.
I am at 87 hp now, and 92 trq, so maybe.... it might make 100hp, and 100 trq. Just wanted a little more get up and go.
Cheers,
Mark
__________________
07 Fatboy: 103 c.i. D&D Fat Cat, Red Shift 575 Cams,Baisley super stock heads and roller rockers,AIM clutch, Feuling oil pump & lifters,S&S springs,SE push rods, Amsoil
Thunder Max, Doherty PowerPACC
* http://markmomb.blogspot.com
Old 03-05-2009, 09:47 AM
Bad Disposition Bad Disposition is offline
Prospect
Default A Little help for the Field
Scott, Old Gunny, Sedeluxe & Hillsidecyclecom,
Will I need a larger than 50mm throttle body to feed the Baisley's Superstock heads, tw6 cam, Thunder Headers and the TTS?
If so, what size will be needed and what is the best on the market?
Dudes, you don't know how much I appriciate your help.
Old 03-05-2009, 02:11 PM
beaureed445's Avatar
beaureed445 beaureed445 is offline
I don't think you'll need a larger throttle body. I'm running a similar set up with a stock throttle body (46mm).
__________________
2007 FXST
D&D Muffler Bearings
Andrews Piston Return Springs
Old 03-05-2009, 05:51 PM
SEDELUXE's Avatar
it might add some power up top but for now no.
with the stock t/b you will have some great tq down low.
__________________
Sae Actual
134 tq 138 tq
142 hp 146 tq
Old 03-05-2009, 07:07 PM
You can look into your TB and see obvious places you can improve. 50 should be more that enough. Can put in bigger HD injectors if you want.
Old 03-05-2009, 07:13 PM
SEDELUXE's Avatar
you could put a 55mm hpi on there if you wanted to. but imo if you dont need to why spend the coin now.
__________________
Sae Actual
134 tq 138 tq
142 hp 146 tq
Old 03-05-2009, 07:58 PM
We see great results from bored 2-piece Delphi's.
We take 'em from 41-46.5mm as we manufacture our own throtttle plates.
Other shops call on us to provide that service quite often.
Remember that not only is the size of the t/body important, but the size/shape of the intake manifold.
One of the reasons that that HPI units rip.
Scott
Tags
9b, baisley, cam, compression, dan, heads, hybrid, stock, super, tw6hg, woods
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
