Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Tech Forums > Engine/Fuel/Intake/Exhaust
Engine/Fuel/Intake/Exhaust Find answers to your engine and fuel problems here.
Sponsored by: Custom Dynamics
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 01-14-2009, 02:25 AM
HERITAGEBOY HERITAGEBOY is offline
Hang Around
Default Mikuni hsr 42 tuning
Gday ive got a 2005 softail ive got s/e 11 pipes breather kit ignition module, coil ive recently added the mikuni but cant get the tuning spot on its got a 160 main 25 slow and 70 nozzle it really seams to bog dowwn either getting to much fuel or not enough when you open it up on the highway around 70 miles
the plugs are sligtly sooty(sign of richness)
and the other day when i got home and turned off the engine there was engine run on (sign of leanness)so im a bit baffles any help would be appreciated
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 01-14-2009, 01:30 PM
new_mentor70's Avatar
new_mentor70 new_mentor70 is offline
Senior Rider
try a 155 main and see what it dose, that 42 is alittle more at home on a 95 ci.
I also bought a tuning kit from Head-Quarters for the midrange fatness that is hard to fix.
__________________
95 Sport/touring HQ big bore kit
.575 Firestorm cams
D&D fat cat
Mikuni 42 mm
magnecor spark cables
Old 01-14-2009, 02:33 PM
Shrink Shrink is offline
Hang Around
Here is a link to an article written by Joe Minton. He wrote the book on the HSR carb... literally. He wrote the tuning guide (which is available in PDF format on Mikuni's website.)
http://www.americanrider.com/output.cfm?id=1581175
He states that the carbs come a bit rich. He recommends a 17.5 idle jet, a #98 needle (which is slightly leaner than the 97), and a #50 accelerator pump. He says the stock main jet is usually correct (160 I believe?). There is a kit that can be purchased from Fox Distrubuting. I believe the number is in the article. I just ordered the kit from them a while back and they were really great to work with. The person I spoke to really understood the Mik carb as well.
Old 01-14-2009, 11:45 PM
Crazy Canuck's Avatar
Crazy Canuck Crazy Canuck is offline
Diddo.
__________________
http://i83.photobucket.com/albums/j3...2006/bike3.jpg
~ Powered by Head-Quarters ~
Old 01-15-2009, 09:38 AM
Senior Rider
For those that are reading this artical, keep in mind that the writer dosnt specify which size engine that his is tuning for with his recomdations, (im assuming its a stock 80 CI evo).
His recomedation wont work for a bike with a big bore, cams and big exhausts, I have tried!!!
A # 20 pilot was just too small on my 95, (i didnt even try the 17.5 they recomend) hard starting and rough idle.
around LA most bikes with aftermarket pipes are using the #27 pilot.
The fatter needel is doable, but the HQ part works better,
I prefer to keep the stock #70 squirter and raise or lower the main jet size to do the fine tuning.
Trying to run the smaller squirters gave me masive pining on hot days when rolling on the throttle. not to mention the lack of power on acceloration.
I almost forgot to add the best advice ive ever gotten about tuning: regardless of what anyone says, just give the bike what it wants!!!
__________________
.575 Firestorm cams
D&D fat cat
Mikuni 42 mm
Old 01-15-2009, 06:18 PM
tym4brk tym4brk is offline
Hang Around
I'm going to read the article, but I wanted to add to this thread since there are some experienced tuners here.
I have a '96 FXDWG with an Andrews EV3 or EV27 (can't remember now), V&H straight shot pipes, the SE air cleaner, Dyna 2000 igntion (single fire) and an HSR42. All of this stuff has been on this bike for 90k miles, 1997 is when I did the work. I had the cylinders refreshed at about 60k miles, SE cast pistons, nothing radical.
The bike is running rough and idling poorly. I replaced the intake manifold gaskets last year, didn't seem to help. I can adjust the idle speed screw so it won't stall, but after riding it for 45 mins or so, when I stop at a light she's racing. I readjust the idle speed and she's OK for the rest of the day. Next day, hard start unless I tighten the idle speed screw in a couple turns. Then the whole process starts again. Seems to me I should not have to adjust the idle speed so much.
I'm certain the carb has the jets it came with and I know I haven't done anything to them in all these years either. Recently mentioned problem to a shop when I brought it in for a timing check and valve adjust. They told me they leaned it out some. The bike is running the same, not that great IMO. She was Cadillac smooth a couple years ago, but this idle speed thing has been going on for some time.
If it matters, I'm in California, so no high elevation stuff to deal with. I run 91 octane fuel.
Maybe my story will spark a thought from the experienced users here. I'd appreciate any recommendations.
Thanks in advance!
Jeff
Old 01-15-2009, 07:24 PM
turn8a turn8a is offline
Senior Rider
If after you read the manual and still have questions you can call mikuni direct and a tech will answer any questions you have.
Old 01-26-2009, 05:11 AM
Hang Around
To new mentor 70 how could a 2005 softail be a stock 80 c/i evo use your brain!!
Old 01-26-2009, 09:36 AM
Senior Rider
My remarks were directed at the post that had the link to the American Rider carb tunning artical, not YOUR bike.
Did you read your own thread?
__________________
.575 Firestorm cams
D&D fat cat
Mikuni 42 mm
Old 01-26-2009, 10:21 AM
KBFXDLI's Avatar
KBFXDLI KBFXDLI is online now
Thanks in advance!
Jeff
Sounds like you have a vacuum leak somewhere. But I would first pull the carb and give it a complete cleaning inside and out. You may want to replace all the jets as well. If you can't do this yourself send it out to a quality rebuilder. Then see what happens.
__________________
06 FXDLI
Many thanks to our people in uniform for it is their courage and sacrifice that makes our nation great.
Tags
175, 42, 45, 95, book, carb, hsr, idle, intake, mikuni, pilot, pumper, racing, reads, screw, single, speed, tuning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
