RE: Have you had crankshaft problems on a 2007 or 2008?
I agree that you do not have to do any mods to have a crank issue or bearing failure. Although increase hp and tq can certainly speed up the end result. It really is a roll of the dice on these cranks. We have had customers build big engines and never have the issue, others do mild mods and they crank goes south, and yet others do nothing to them and still have failures. Even the after market cranks are questionable as to proper set up. \\; We had a \\; a Jims crank fail \\; with 1800 miles send it \\;back to them wait a few weeks and get it back with a l\\;etter stating nothing wrong. Send it to Hobans find that the it needed a +2 pin and along with new races and the original one where egg shaped. All said and done I get back in touch with Jims to report what we found, there statement was simple. " there is no need to run a crank pin that tight a small amount of rod knock with a longer storker crank is normal" WTF??!!! \\; S&\\;S cranks pretty much same story, we dont even bother running them stock either. Just let Hobans do there \\; stuff and we know that it is right and ready to go.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
+1 on Hoban's - \\; Darkhorse Crankworks.
I have maintained all along it is a crapshoot with the stock cranks, particularly when doing a build. \\; It isn't a problem that is quantifiable at this time as I dont think anyone other than HD has tracked this problem and obviously they are not going to disclose the number of failures, but still, it does exist and HD knows it exists, that is why the acceptable factory tolerances were changed, if left to pre 07 specs HD would have been replacing a lot of cranks. \\; This has been a problem for some time as ther have been failures of a few pre 07 cranks that I am aware of, but the larger dispacement 96 and 110 from the factory have magnified the problem and now with the bigger bore and stroke engines being built with better aftermarket components, more power is being made, again, magnifying the problem. \\;
__________________ 07 120" Hotrod Bagger
HeadQuarters Top End, Darkhorse Crank, Primo Pro Clutch,D&D Borzilla
TP Rocker Boxes, HPI 55mm TB, TTS , Baker DD7 Built by owner 125Hp/145Tq SAE Corrected
Renegade Wheels, Paint by Attitude Custom Painting
have them put it back together and on your way home keep locking the rear tire up with out pulling in the clutch and keeping it in gear \\;and it will throw the crank so far out of specs even your dealer could see it.
its not right but neither is spending 20 grand for something that is not right to begin with.
__________________
120 ci..Heads - Baisley fastest reving and cool running ..Crank - S&S ...cylinders - Axtell...pistons - Axtell...Throttle body - HP Inc ....Cam - Woods ...Exhaust - Borzilla
Sae Actual
134 tq 138 tq
142 hp 146 tq
"Doc and JD's cycle works"
Done Once Done Right
So, if these cranks are bad...Are they bad from the factory? Or do they go bad over time and miles? I guess what I'm trying to find out is: If I have the crank runout checked on my bike before doing a build and it is say .003 does that mean that mine is OK? Or will the runout increase over time until it causes problems?
I have an '07 FLHR with 14,000miles on it. Arlen's Big Sucker, Slip-Ons, T-max and was considering doing a 575 cam this winter. But maybe I don't want to add the cam if the crank is "shaky"?
So far, without the cam, it seems to be OK even after 14K. I don't have any knock or vibration (ok, no excessive vibration for a big twin Harley anyway).
__________________
2007 Harley Road King Standard
Arlen Ness Big Sucker Air Cleaner
Fishtail Slip-Ons
T-Max ECM
I seriously doubt that any 07/08 is .000" or even .001".what you have [.003"] seems to be the norm. That being its the luck of the draw.How you ride will play into this. Upping the performance will only play into those cranks failing easier.
I got back from Myrtle on Sunday a week ago and on the way to work on Tuesday I noticed the windscreen was vibrating at 50 mph were it had always been glass smooth. The next day it was even worse, the highway pegs would actually vibrate into the down position.
I took it to a Harley certified independent shop and they showed me the primary side showing .017 runout. MOCO would not authorize them to do the work. I was told I had to take it to a dealer!
Now I'm pissed... this the nicest bike I've ever owned and the worst also! It's had the whole gamut of '07 problems. Primary chain overtightening, of course the clatter, the fairing brackets breaking, overheating, and now the crank. Sheesh, at 22,000 miles this thing is running me broke! At least I got my vacation in! I don't abuse this bike in any way, I just ride it ...when it's available!
