Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Tech Forums > Engine/Fuel/Intake/Exhaust
Engine/Fuel/Intake/Exhaust Find answers to your engine and fuel problems here.
Sponsored by: Custom Dynamics
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 05-07-2008, 11:37 PM
kevdog's Avatar
kevdog kevdog is offline
Senior Rider
Default Changing carb needle
I want to install a Stage I air and a sportster needle (27094-88) in my 2000 Softail. How difficult is it to change the needle? Do I need to remove the carb altogether?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 05-08-2008, 12:04 AM
BAGGERDSM's Avatar
BAGGERDSM BAGGERDSM is offline
Default RE: Changing carb needle
No, you dont need to remove the carb off the bike, but its easier to. You can just remove air cleaner assembly, and pull the carb off the manifold and let it "hang" from the cables and fuel line. Pull off the throttle cable bracket and top cover, than the spring and plastic spring base and finally the needle. Install new needle and i recomed to let the slide sit outside in fresh air for a bit to "dry up" and shrink. Careful with the slide diaphram as its fragile and about 40.00 to replace if you tear it.
__________________
Hillside Cycle 117 build
Hillside Custom heads~Axtell 117 cyl+pistons~Mikuni HSR48 with "D" manifold~Wood TW9BG cams~DTT~Rivera ProClutch w/VPC~Boarzilla~S+S Rockers~etc......
Built by me, Machine work/porting by Hillside Cycle, Tuned by Jd's Cycle Works...
<a href=http://i78.photobucket.com/albums/j91/baggerdsm/danny3018-1-1.jpg target=_blank>http://i78.photobucket.com/albums/j9...ny3018-1-1.jpg</a>
Old 05-08-2008, 10:18 AM
CelticCB CelticCB is offline
Hang Around
Location: San Diego, NAB. But I reside in Oxnard, Ca with my lovely wife Suzanna
I agree with the machanics but I would rather take it off because if you are not carful you will loose parts and they are small just to be on the safe side I like to do things on the bench when I have the option. If I was on the road it would be diffrent just make your self comfortable and do the job right. If you have the Kehin carb I can tell you how to do some mods to it for more throttle responce..Just letting you know. Happy Riding!
__________________
Ride Hard Ride Fast and never mind who is behind you unless your a couch potato!
Old 05-08-2008, 07:19 PM
mtclassic mtclassic is offline
I never remove my carb. I lift the back of the tank up and support it with a block of wood. This gives me plenty of room to remove the carb top using a stubby screw driver (I got it from snap on and it is very short and uses a small box end wrench to turn it). I can change needles in about 5 minutes. I stick the slide in a plastic zip lock and pop it in the freezer for a few minutes and it makes it easier to put back in. I have done this about a 100 times with no problems and it is a lot easier than taking the carb off.
Old 05-09-2008, 12:35 AM
kevdog's Avatar
Senior Rider
So with putting on the Stage 1 air and sportster needle (with free-er flowing mufflers) how many turns out from flush should I turn the idle mixture screw? I'm at sea level, if that makes a difference.
Old 05-09-2008, 12:54 AM
BAGGERDSM's Avatar
Every bike will be diffent..Look in the carb tuning section here. It gives a good way to test it. Always best to get the dyno sniffer to check but going by the tuning manual will get you close.
__________________
Old 05-10-2008, 07:51 PM
Hang Around
Quote:
ORIGINAL: kevdog
I would start with 2 from the start the 1/4 turns there after.
__________________
Tags
2709488, needle, sportster
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
