Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Tech Forums > Engine/Fuel/Intake/Exhaust
Engine/Fuel/Intake/Exhaust Find answers to your engine and fuel problems here.
Sponsored by: Custom Dynamics
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 04-29-2008, 08:09 PM
neonhomer's Avatar
neonhomer neonhomer is offline
Senior Rider
Send a message via Yahoo to neonhomer
Default RE: Engine seems to tap TOO much...
More info... Popped the pushrod tubes off to check the pushrods. The front intake (I think, the pushrod closest to the intake port on the front cylinder.) pushrod spun really easy. No play, but really easy to spin with one finger. Others required a finger & thumb.
Anyway, the bike goes to the dealer on Friday. Anything I should tell them, request, or look out for? I am planning to mark down how many miles are on the bike, and to request to see any gaskets changed during inspection. If any parts are replaced, I am also going to ask to see them.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
NeonHomer
2004 Road King Police FLHP/I *Dynojet PC3 USB * Screamin' Eagle Stage 1 A/C
Old 05-03-2008, 09:25 AM
neonhomer's Avatar
Senior Rider
A lot of people reading, but no one writing.... reminds me of another thread I did on another board...
Anyway, took the bike over to the dealer yesterday. The service manager started by telling me the usual... TC88's sound like sewing machines... nothing they can do about it. However, he said he will still look into it, and said he will take it for a test ride. Says he will be gone for about 10-15 minutes as they go for 10 miles or so. He takes off, and comes back two minutes later, and goes right in the shop.
"I can't blame you for being concerned, it is making all kinds of racket, and it's not a light load noise either." (Or something to that effect.)
So, now I am waiting to see what they say. In the meantime, I have to drag the old Honda out and ride it if I want to ride anywhere. Sometimes I miss my old Honda...
__________________
NeonHomer
Old 05-03-2008, 10:13 AM
TymToPla TymToPla is offline
Hang Around
Been reading and not writing but nothing to add except intrest. Please keep going with the updates.
Old 05-03-2008, 10:26 AM
xxxflhrci xxxflhrci is offline
Quote:
ORIGINAL: neonhomer
You did rotate the engine so the lifter was fully down (valve closed) before you checked each one didn't you? If you did not do that, you findings don't mean anything. Of course, to do this "check" you gotta wait a while after you shut the engine off to let the lifters bleed down.
__________________
2000 Road King Classic. Andrews 26G cams, SE Stage I, DFO, V&H True Duals with Samson Fishtail Mufflers.
1977 XLH, Nearly bone stock.
Old 05-04-2008, 01:04 AM
neonhomer's Avatar
Senior Rider
I did that with the engine overnight cold. Yes, I pulled the plugs and rotated the motor to where both lifters were down (in compression stroke at TDC).
The dealer called me today... said the bike is ready. They had two guys go over it and they said they couldn't find anything wrong. I am assuming they didn't go into the motor, though. <Shrug? This noise is just driving me up the freakin wall. It makes the bike sound like crap.
I guess I am going to invest in a Bailey spring (if I can find one.. J&P sells some kind of spring for the TC88 that is supposed to increase oil pressure...), and maybe the adjustable pushrods. Maybe I can get rid of a majority of the noise. My next move is to try synthetic oil. Wonder if I can find 50w in a synthetic? Either that or it's Amsoil 20w50...
I had a thread on another board that went like this. It was about rebuilding roofs in popup campers. I just kept adding info and adding info with no one posting. It's now considered required reading when someone is considering redoing their roof in their popup!
__________________
NeonHomer
Old 05-04-2008, 01:33 AM
chaos5 chaos5 is offline
Prospect
My sporty has a lot of ticking at lower RPM's. I changed to Mobil 1 V-twin at the last oil change. It still has the ticking, but it's not as bad.
__________________
2008 XL1200C
Old 05-04-2008, 09:32 PM
neonhomer's Avatar
Senior Rider
Well, went and got it back today. Still taps like a bitch. I don't know...
I did an oil change to 50w... I think the next step is to go to 20w50 synthetic and the spring. Either that or it's a swap to adjustable pushrods... Bad thing is if I do it myself, then it will void the warranty....
__________________
NeonHomer
Old 05-06-2008, 07:24 PM
neonhomer's Avatar
Senior Rider
Y`know, it just dawned on me... The service manager said they were going to check my cam tensioners, and he never said anything about if they did or not...
Looks like I need to... but too afraid of pulling the exhaust... (never fails.. I pull an exhaust and break a stud...)
__________________
NeonHomer
Old 05-06-2008, 08:59 PM
2005UltraNC's Avatar
2005UltraNC 2005UltraNC is offline
Can you pin point where the noise is coming from? Assume the oil level is okay. What do the spark plugs look like?
Cam tensoniers check is at 30,000 miles - this usually isn't a ticking noise.
__________________
95"Big Bore,HD Flat Top Pistons, Andrews TW-26G ,
SERT, Feuling Super Oil Pump, Feuling Lifters
HD Adjustable Pushrods, Big Boyz Ported 9.5, FAT CAT 2in1
Old 05-06-2008, 10:44 PM
neonhomer's Avatar
Senior Rider
Oil is okay, and fresh. 50w HD oil and filter. Spark plugs have 1000 miles on them, and are okay.
Sound is most noticable when riding, where it comes up from between the tank and windshield. When off the bike and at idle, it sounds like it is coming from the front rocker cover. No weird noises from the cam cover. Putting a mechanics stephescope up to the rocker cover you can hear a defined "click" in a rythym with the rpm of the motor, like there is excessive clearance in the valvetrain.
Unfortunatley, I can't seem to get a dealer to agree with me and go into the top end of the motor. Even to take the rocker covers off and check. I have the extended warranty, so they would get paid, but they all seem like they don't want to be bothered with working on my bike.
__________________
NeonHomer
Tags
ams, davidson, engine, harley, hitting, hylift, lifters, oil, pushrods, roadking, tap, tapping, tube, tubes, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
