Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Do It Yourself Help Forum > Engine Diagnostics , Alarm, and Fuel Injection Issues
Engine Diagnostics , Alarm, and Fuel Injection Issues Tips on Engine Diagnostics, how to get codes, and what they mean.
Welcome to HDForums.com!
Welcome to HDForums.com.
Closed Thread
Thread Tools Search this Thread
Old 08-28-2005, 12:40 PM
HDF Tech HDF Tech is offline
Default Cruise Control Diagnostics and Codes
Here is how to pull the cruise control dropout codes and what they mean. They tell you why the cruise control disengaged. The module stores the last 8 dropout codes starting with the most recent dropout.
To invoke the readout:
Engine OFF, cruise switch OFF
Push cruise set/resume switch to SET and HOLD it there while switching to IGNITION (do NOT start engine)
RELEASE the set/resume switch and watch the cruise enabled lamp....it will flash out 3 digits encoded as a series of pulses in the following pattern >>> the first digit is string of 1/4 second flashes, then a one second pause; then the second digit is string of 1/4 second flashes, then a one second pause; then the third digit is string of 1/4 second flashes and it stops.....write down the number of flashes in each of the three segments and you will get a three digit code
if you want to verify the flashes you just saw, then push the switch to RESUME and it will repeat the three digit code that you just read.....
to get the next three digit code that is stored, push the switch to SET and three more digits will be pulsed out in the same format as above.....continue advancing the codes by toggling to the SET (or verify them using RESUME)
there are 8 codes stored and once the buffer is empty, the cruise engaged lamp stays on solid.........if you want to repeat all 8 again, then toggle the switch to SET
to exit the readout mode switch the ignition to OFF
You now have 8 three-digit codes written on your arm....their meaning is:
111 No Codes, memory clear
112 Throttle roll off
113 Cruise switch turned off
122 frt or rear brake applied
211 Coast interval longer than 6 seconds (S/C button)
212 speed dropped below 30 mph while s/c button held
213 speed below 26 mph or above 90 mph
221 speed drops more than 15 mph below speed set point
222 speed decrease exceeds 20 mph per second
223 vehicle speed sensor input
231 rpm exceeds 5000
232 tach signal lost
242 high rate of engine rpm change (e.g., hit ice or slipping tire)
341 low voltage
internal failure if code 311, 312, 313, 321, 323, 331, 332, 333, 342, 343, 351, 352, 353, 361, 362, 363, 371, 423, 432, 777
Source: Private
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Closed Thread
Tags
122, alarm, changing, code, codes, control, cruise, davidson, diagnostics, flashing, harley
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
