Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Do It Yourself Help Forum > Engine Diagnostics , Alarm, and Fuel Injection Issues
Engine Diagnostics , Alarm, and Fuel Injection Issues Tips on Engine Diagnostics, how to get codes, and what they mean.
Welcome to HDForums.com!
Welcome to HDForums.com.
Closed Thread
Thread Tools Search this Thread
Old 06-28-2005, 06:49 PM
HDF Tech HDF Tech is offline
Default Alarm Key Fob Assignment
This must be done when you buy a new key fob for the alarm if you loose one.
I assume you know your personal entry code using the directional switches and the key switch to activate , if not , it's in the owners manual.
If you never set the code, its 7-7-7-7-7
1. Set run switch to off
2. ign to acc
3. hold both turn sigs till lights flash
4. use left turn signal to enter number by pushing 7 times
5. use right turn signal as enter key
6. repeat until all 5 are entered and you hit enter
lights should flash and you should be OK.
KEY FOB ASSIGNMENT
The key fob on TSSM motorcycles must be set so it will operate the alarm system on the vehicle.
This assignment must be completed with no pauses between steps greater than 10 seconds.
Turn the ignition OFF after all key fobs have been assigned.
The programming mode will also exit after 60 seconds has elapsed without detecting any fob signup messages
or turn signal switch activity.
Two key fobs may be assigned to the TSSM.
The first successful attempt to program a fob will disable all previously assigned fobs.
If a second fob is to be programmed, it must be done in the same programming sequence as the initial fob.
Source: http://www.harleyhog.co.uk/
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Closed Thread
Tags
2005, alarm, assignment, davidson, fob, forum, harley, issue, key, program, programing, programming, sportster, system, tssm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
