Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Do It Yourself Help Forum > Engine Diagnostics , Alarm, and Fuel Injection Issues
Engine Diagnostics , Alarm, and Fuel Injection Issues Tips on Engine Diagnostics, how to get codes, and what they mean.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 07-14-2009, 09:05 AM
eaglesmog03 eaglesmog03 is offline
Hang Around
Cool dyna 03 / blinking lights/ gauges not working
ok, so i get up saturday morning to go on a poker run for burn camp. I go outside to check the oil, start my dyna wide glide up go back in the house for a minute so the bike can warm up, my senior satues kicks in and i forget the bike is running. about a half hour later it hits me. i run outside and turn the bike off. a little later i head out. one would think that since i am about to go on a ride to help kids that have been burned go to camp that the good lord would be good to me. NO SUCH LUCK. the bike ran great, BUT, through the 200 miles my speedo, gas gauge, auto turn signals were for most of the trip not working. when i would turn on the bike after each stop my emergnancy flashers would flash about 6 times ( no security system) lets just say all the indicator lights were going haywire. when i got home the bike smelled sort of like rotten eggs????? I had to wait until Monday to call the hd dealership who informed me they would not be able to look at bike for about 2 weeks. so i ask, any ideas. No, he says, none of that sounds familiar to me, we'll have to look at it. I asked if my leaving it running that morning could have messed something up, no he says. Hmmmmm, I don't want to wait 2 weeks, I feel like i am between a rock and hard place. I have had past experiences with my local hd dealership and they are not always very honest. so i start researching the internet. being both old and not internet savy, i did not get to far. i tried to find fail codes for the 03, it could be i am just stupid or they are a big secret. so my son comes over, we try to start the bike and click, click, click. we took the battery off his bike and got a click and it roared to life. we tried 3 times to start bike up with his battery and got that clicking b4 it roared it life. i told him to take the battery off bcuz i did not want his battery draining. can anyone give me any ideas? I talkes to one guy who suggested it could be the battery and the votgage regulator. the battery is the orginal. i can throw a new battery on but would it drain? and would the battery going bad cause all those indicators to stop working and the check engine light to go on. I am not sure what my kid did but he came up with a code 11. anyone know what that mean? HELP, I am lost without my harley
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 07-14-2009, 09:37 AM
jknowlton's Avatar
jknowlton jknowlton is offline
2007 Harley Davidson Softail Night Train
Code 11 is Battery voltage high. Could be the voltage regulator or the battery tender if using one, what is the voltage on the battery?
Not sure of the egg smell but maybe something burned out or a wire is shorting or something, causing the electronics to go hay wire. Run the diagnostics if you can on the bike.
__________________
07 FXSTBamf
US Army Iraq Vet
http://i113.photobucket.com/albums/n203/specopsjay/Private/user61979_pic7329_1221678942.jpg
Ride to live. Live to ride. Ride to work. Work to ride.
Old 07-14-2009, 04:43 PM
Hang Around
theres the thing, i can't seem to figure out how to run the diagnostics. we came up with something like p 085 but the last # seemed to look like some sort of weird E
Old 07-14-2009, 04:46 PM
jknowlton's Avatar
I am not sure on your year of bike, let me see what I can dig up.
DTC error codes
DTC FAULT CONDITION MODULE
B0563 Battery Voltage High TSM/TSSM
B1004 Fuel Level Sending Unit Low Instruments
B1005 Fuel Level Sending Unit High/Open Instruments
B1006 Accessory Line Overvoltage Instruments
B1007 Ignition Line Overvoltage Instruments
B1008 Reset Switch Closed Instruments
B1131 Alarm Output Low TSM/TSSM
B1132 Alarm Output High TSM/TSSM
B1134 Starter Output High TSM/TSSM
B1135 Accelerometer Fault TSM/TSSM
B1151 Sidecar BAS Low TSM/TSSM
B1152 Sidecar BAS High TSM/TSSM
B1153 Sidecar BAS Out of Range TSM/TSSM
P0106 MAP Sensor Rate of Range Error Carb
P0107 Map Sensor Failed Open/Low Carb
P0107 Map Sensor Open/Low EFI
P0108 Map Sensor Failed High Carb
P0108 Map Sensor High EFI
P0112 IAT Sensor Voltage Low EFI
P0113 IAT Sensor Voltage Open/High EFI
P0117 ET Sensor Voltage Low EFI
P0118 ET Sensor Voltage Open/High EFI
P0122 TP Sensor Open/Low EFI
P0123 TP Sensor High EFI
P0261 Front Injector Open/Low EFI
P0262 Front Injector High EFI
P0263 Rear Injector Open/Low EFI
P0264 Rear Injector High EFI
P0373 CKP Sensor Intermittent Carb
P0373 CKP Sensor Intermittent EFI
P0374 CKP Sensor Not Detected Carb
P0374 CKP Sensor Synch Error EFI
P0501 VSS Low Carb
P0501 VSS Low EFI
P0502 VSS High/Open Carb
P0502 VSS High/Open EFI
P0505 Loss of Idle Sped Control EFI
P0562 Battery Voltage Low Carb
P0562 Battery Voltage Low EFI
P0563 Battery Voltage High Carb
P0563 Battery Voltage High EFI
P0602 Calibration Memory Error Carb
P0603 EEPROM Failure Carb
P0603 ECM EEPROM Error EFI
P0604 RAM Failure Carb
P0605 Program Memory Error Carb
P0605 ECM Flash Error EFI
P0607 Converter Error Carb
P1001 System Relay Coil Open/Low EFI
P1002 System relay Coil High/Shorted EFI
P1003 System relay Contacts Open EFI
P1004 System Relay Contacts Closed EFI
P1009 Incorrect Password Carb
P1009 Incorrect Password EFI
P1010 Missing Password Carb
P1010 Missing Password EFI
P1351 Front Ignition Open/Low Carb
P1351 Front Ignition Open/Low EFI
P1352 Front Ignition Coil High/Shorted Carb
P1352 Front Ignition Coil High/Shorted EFI
P1353 Front Cylinder No Combustion EFI
P1354 Rear Ignition Coil Open/Low Carb
P1354 Rear Ignition Coil Open/Low EFI
P1355 Rear Ignition Coil High/Shorted Carb
P1355 Rear Ignition Coil High/Shorted EFI
P1356 Rear Cylinder No Combustion EFI
P1357 Intermittent Secondary Front EFI
P1358 Intermittent Secondary Rear EFI
U1016 Loss of ICM/ECM Serial Data Instruments
U1016 Loss of ECM Serial Data, Vehicle Speed, Vehicle Inhibit Motion or Powertrain Security Status TSM/TSSM
U1064 Loss of TSM/TSSM Serial Data Carb
U1064 Loss of TSM/TSSM Serial Data EFI
U1064 Loss of TSM/TSSM Serial Data Instruments
U1097 Loss of Speedometer Serial data Carb
U1097 Loss of Speedometer Serial data EFI
U1097 Loss of Speedometer Serial data TSM/TSSM
U1255 Missing Message at Speedometer EFI
U1255 Serial Data Error/Missing Message EFI
U1255 Serial Data Error/Missing Message Instruments
U1255 Serial Data Error/Missing Message TSM/TSSM
U1300 Serial Data Low Carb
U1300 Serial Data Low EFI
U1300 Serial Data Low Instruments
U1300 Serial Data Low TSM/TSSM
U1301 Serial Data Open/High Carb
U1301 Serial Data Open/High EFI
U1301 Serial Data Open/High Instruments
U1301 Serial Data Open/High TSM/TSSM
__________________
07 FXSTBamf
US Army Iraq Vet
Last edited by jknowlton; 07-14-2009 at 04:52 PM. Reason: not the right information
Old 07-14-2009, 04:53 PM
jknowlton's Avatar
04/05 bikes
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range
and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module)
to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module (EFI) / (Ignition Control Module, 'Carbureted')
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be
displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up.
Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 9.
If the code is current it will reappear.
9 – Press and release the odometer reset button to continue to the next module.
10 – Turn Ignition switch to OFF.
__________________
07 FXSTBamf
US Army Iraq Vet
Old 07-14-2009, 05:50 PM
Hang Around
i will try this, although my bike is a 03 i will see what i come up with. thanks
Tags
04, code, davidson, engine, flashing, gas, gauge, glide, harley, lights, signal, start, tssm, turn, u1097, wide
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
