Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Do It Yourself Help Forum > Engine Diagnostics , Alarm, and Fuel Injection Issues
Engine Diagnostics , Alarm, and Fuel Injection Issues Tips on Engine Diagnostics, how to get codes, and what they mean.
Welcome to HDForums.com!
Welcome to HDForums.com.
Closed Thread
Thread Tools Search this Thread
Old 03-09-2006, 10:08 PM
HDF Tech HDF Tech is offline
Default Setting Idle On MM Systems
You need to make sure the throttle cables are not hanging up, are lubed properly and the throttle is closing all the way, and the throttle return spring is OK. If all this checks out:
I'm assuming you have MM EFI. If so:
1. Remove your right saddlebag and side cover.
2. Remove air cleaner assembly
3. Start the bike and make sure it is at normal operating temp.
You Need A Tach For This Part:
4. Adjust the hot idle to 950/1050 rpm.
5. Unplug the temp sensor.
Your bike now thinks it's cold!
6. Set the cold idle to 1500rpm
7. Shut the bike off.
8. Remove the 5 and 15 amp fuses from the fuse block which is on the side you took the cover off of.
9. Plug the cold sensor connector back in.
10. Replace the air cleaner assembly.
11. Wait at least 30 minutes, then replace the 2 fuses
12.Replace the side cover.
13. Replace the saddlebag.
When you restart your bike, the ECM should remember the new idle settings you did .
A different way of doing the above mentioned that I found if you have no luck with setting it...
This describes a method to set cold and hot idle speed on Magneti-Morelli EFI systems.
First, when it comes to setting cold idle, the service manual leads you down a path of frustration. This is a very simple and effective way of adjusting it. If you start the engine stone cold and it idles below 1200 rpm (after it stabilizes) then turn the cold idle screw (in linkage, on the side that rotates with the throttle plates) in. If it's over 1300 rpm, then turn the screw out (therefore, set cold idle speed at 1200 rpm for TC-88's)It's that easy . Also, to guarantee that the idle will be recognized by the ECM, run the bike until it's fully warmed up, turn the hot idle (in the throttle body, forward of the front intake, near the bottom) up to 1200 rpm, shut off the ignition and pull the 5 amp fuse (in the fuse holder on the ECM brackett), run a lead from the cold (relay) side of the 5 amp socket to ground. Let it sit for 15 minutes or longer if practical, then put the fuse back in and warm it back up, turn it back down to 1000. Works like a charm.
The Magnetti Morelli was used on baggers from 96-01 never on Softails. The Delphi is used on the Softails and all '02 and later baggers.
Also check... HERE
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Closed Thread
Tags
cold, davidson, engine, fuel, harley, hot, idle, injection, magneti, morelli, sensor, set, setting, settings, speed, temperature, unplugged
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
