Engine Diagnostics , Alarm, and Fuel Injection IssuesTips on Engine Diagnostics, how to get codes, and what they mean.
Welcome to HDForums.com!
Welcome to HDForums.com.
Using a DVOM ,the TPS signal wire should be the one furthest to the right on the sensor, it probably is grey purple (CRS), easy to find out one of the others is going to be ECM/chassis ground and the other 5V feed. You measure between the signal wire and chassis ground, preferrably at the battery negative.Voltage specs are as follows. .41 for 01-03 and .52 for 04's in the idle position. The values increase as the throttle is opened to max voltage. The Problem is, is that you must also reset the IAC (intake air control) motor now that you have adjusted it. The later models are not adjustable. It can only be reset with a Scanalyzer or DT by the dealer.
The older morelli bikes were adjustable with elongated slots in the TPS switch, but the delphi units are not adjustable and need to be replaced if they do not work correctly.
If you venture to remove the plug that covers the Idle setting screw to change this setting, the ECM will return the speed to where it was before you changed it and eventually set a code. Don't be tempted to do it, or it will throw other settings out also.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
