Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Tech Forums > Electrical/Ignition/Tuner/ECM/Fuel Injection
Electrical/Ignition/Tuner/ECM/Fuel Injection Having electrical problems? Need advice on ignition issues? Questions about a tuner? Have questions about a MAP or Fuel Injection? Find your answers here.
Sponsored by: Phat Performance Parts
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-16-2009, 11:13 PM
Newhog Newhog is offline
Senior Rider
Default Another...Mystery Engine Shut Down
2000 Ultra Classic all stock, 12,000 miles, all service done at dealer.
Intermitant complete power shut down, seems to be heat related, when in heavy tracffic the bike will completely lose all power.
We have upgraded the main circuit breaker, changed all relays, checked all wiring, turned off all unecessary items like passing lamps, radio, etc.
I've had it to three dealers and an Indy, they have drove it home for a week, ran it hard on a dino, changed some componets, did the circuit breaker upgrade.
No one can seem to find the problem.
It's getting dangerous to ride this thing, going down the street or on the highway, then all the sudden complete shut down, no power to anything.
Let it sit for a couple minutes it comes back to life, like a bad circuit breaker or relay, but like I said, all of that has been changed.
Anyone have any ideas?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
Newhog
99 Ultra Classic, 95 Inch Big Bore, S&S Gear Cams, SE Turn Downs, PCIII, HogTunes
Old 10-16-2009, 11:39 PM
2003Springer's Avatar
2003Springer 2003Springer is offline
Does the weather effect it? happen more when it is hot?
Old 10-17-2009, 12:05 AM
the blob the blob is offline
Prospect
sounds like the voltage regulator.
__________________
the blob- 06 superglide 1 3/4 inch. classic drag pipes,tts tuner and se/ac.
Old 10-17-2009, 05:23 AM
bagga bagga is offline
if there is an ignition circuit breaker check that. it's different than the main breaker.
Old 10-17-2009, 10:21 AM
stroker1948 stroker1948 is offline
Prospect
The engine temperature sensor will cause the problem you are describing. It's mounted on the rear cylinder on the left side. Has this been changed ?
Stroker
__________________
Robert Partee
Old 10-17-2009, 10:14 PM
geargrinder's Avatar
geargrinder geargrinder is offline
Have you replaced your battery? A heat induced internal open on the negative or positive terminal would cause such a problem. A fuel injected engine cannot run without any battery voltage due to the ECM and fuel injectors, unlike a carbed engine. (You cannot push start an EFI engine to get it started if the battery is very low or dead.)
Also, there is a major ground from the battery to the frame, if I recall, under the seat, in front of and near the battery. Has it been removed, cleaned well and re-installed to the frame?
__________________
01 Ultra Classic, 107 CI Twin Cam, S&S ported/polished heads, SE Throttle Body, Andrews TW32HG Cams, S&S Cam Gear Drive & Roller Rockers, Rivera Clutch, S&S VFI ECU, Baker 6-Speed, Vance & Hines Mufflers.
Old 10-17-2009, 11:46 PM
KBFXDLI's Avatar
KBFXDLI KBFXDLI is offline
Does your bike have a bank angle sensor? If so check it as well.
__________________
06 FXDLI
Many thanks to our people in uniform for it is their courage and sacrifice that makes our nation great.
Old 10-22-2009, 11:48 PM
Senior Rider
These are all great responses and suggestions thank you all!
How do I check these componets without just replaceing them?
Such as the battery, as it does start the bike and is never on a tendor, it does hesistate though but that could be due to compression.
I'm good with a meter but don't know what tolerance to look for on the bank or temp sensor, and the battery draw?
I've also been advised that the ring terminals on some of the circuits coming from the silver side of the main breaker are to thin causing it to trip. I'm curious why these ring terminals are not copper as well as that side of the circuit breaker? Can these be replaced with copper ring terminals or does that create some other kind of issue?
Thanks again,
10-17-2009 08:46 PMKBFXDLIDoes your bike have a bank angle sensor? If so check it as well. 10-17-2009 07:14 PMgeargrinderHave you replaced your battery? A heat induced internal open on the negative or positive terminal would cause such a problem. A fuel injected engine cannot run without any battery voltage due to the ECM and fuel injectors, unlike a carbed engine. (You cannot push start an EFI engine to get it started if the battery is very low or dead.)
Also, there is a major ground from the battery to the frame, if I recall, under the seat, in front of and near the battery. Has it been removed, cleaned well and re-installed to the frame? 10-17-2009 07:21 AMstroker1948The engine temperature sensor will cause the problem you are describing. It's mounted on the rear cylinder on the left side. Has this been changed ?
Stroker
Stroker 10-17-2009 02:23 AMbaggaif there is an ignition circuit breaker check that. it's different than the main breaker.
__________________
Newhog
Old 10-23-2009, 04:44 AM
Ram's Avatar
Ram Ram is online now
Have you checked the keyed ignition switch? Friend of mine had similar problem switch arced over internally and would heat up changing positions of contacts then open the ckt.
__________________
'06 FLHRI Road King, ULTRA dress, o2's, TTS tune, LSR 2-1 Black Holes quiet pipe
Non sibi, sed patriae
Old 10-24-2009, 01:05 PM
Senior Rider
Interesting, I don't think it's that at all but I will check.
Thanks,
__________________
Newhog
Tags
01, 2009, engine, fuel, harley, injection, power, recall, rod, sensor, shuts, strarts, street, temperature
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
