Electrical/Ignition/Tuner/ECM/Fuel InjectionHaving electrical problems? Need advice on ignition issues? Questions about a tuner? Have questions about a MAP or Fuel Injection? Find your answers here.
So after a long day of riding we are coming back thru downtown. Lots of stop and go, long waits for pedestrians crossing the road ect.. Well by the end of the strip my bike goes into Heat Management mode. No biggie its done it before, just kinda idles a little rough. Except this time.
While sitting at a light my bike starts to go into EITMS, the light turns green and I start to move, but I'm still down town so I get enough momentum to get going forward then pull the clutch in and coast. Back into EITMS and then into STALL. When I fire it back up most of the bystanders are ducking for cover and a few screamed. Rough neighborhood? Bike backfires in a cloud of grey smoke. Luckly I was at the end of the strip so had some time to run it and get the heat back down before the next light. No more problems for the rest of my ride.
Well I have TTS so I am wondering if there are any tuning sollution to keep my bike from stalling? I do have the option to turn if off in TTS, but I would like to keep it for the times I am stuck in crap traffic.
Any Ideas?
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
Oil cooler and my fan kit will keep it from overheating while stuck in traffic. I was in Laughlin for the river run and while my buddies Heritage got up to 265F while sitting in traffic, my Evo with a cooler and fan kit never got past 195F.
Milan
Milan, thanks but an oil cooler is about the last think I want to bolt on to my bike, much less some fans to blow on the oil cooler. I don't think I am at that point yet, but if this continues to be a problem throught out this summer I may consider it.
We went to the Leesburg bike show last month. It was very hot day. My 08 softail oil temp got up to 295 according to the tank temp gauge. Bike went into heat management mode, shut off spark and fuel to rear cylinder, but came back on once we were moving again. But no stalling problem, just ran on 1 cylinder for a while.
Thanks Shepherdboy, I think I found the root of my problem by data logging it in my TTS. When I am stopped and am ready to move foward I typically engage the clutch to get to the friction zone then once I feel it catch give it some gas. In EIMTS mode one cylinder isnt' enough to have the bike operate like it normally does and its not until I hit the throttle which I beleive kicks it out of EITMS. I did this twice in my data logging and noticed that the first time I applied throttle at 659 RPM and was able to recover, next time around not so much and the RPM fell down a back hole in to a stall. I can only guess that this is what happened to me in my rolling stall lastnight.
I think it would be very easy for me to stall this bike out in EITMS as the handling characteristics could change from one light to the next, and in the riding I do it doesn't get a chance to active very often. I am considering turning it off.
