Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Tech Forums > Electrical/Ignition/Tuner/ECM/Fuel Injection
Electrical/Ignition/Tuner/ECM/Fuel Injection Having electrical problems? Need advice on ignition issues? Questions about a tuner? Have questions about a MAP or Fuel Injection? Find your answers here.
Sponsored by: Phat Performance Parts
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 04-21-2006, 02:33 AM
Shovelhead Bob Shovelhead Bob is offline
HDF Tech Moderator
Default Cruise Control DTC Chart
Here is the Cruise control DTC Chart... Sorry for the poor copy, but I am but a poor Tech....
This is for the 03 and newer bikes with cruise... Whether factory install or P&A...
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 05-18-2006, 11:49 PM
dyna2319 dyna2319 is offline
Senior Rider
Default RE: Cruise Control DTC Chart
SH Bob,
The sheets need to be centered a little better I can't read what they say it is difficult to follow what is happening when viewing the files. Are there three blocks on the sheet? I have yet to figure out how to post pictures correctly myself yet. Will need to spend an evening testing it out myself.
Dyna 2319
06 FXDWG/I
__________________
Dyna2319
06 FXDWHI with more mods than both the wife and girlfriend know about
Old 05-30-2006, 12:05 AM
Coaster's Avatar
Coaster Coaster is offline
Had to look around a bit but thought there was some good info I saw on this. Try this link http://www.hdforums.com/m_104421/tm.htm
__________________
Old 09-17-2007, 07:39 PM
HDroadking02 HDroadking02 is offline
Hang Around
My bike is showing a232 and a242 code what and where do i need to look to see whats wrong? Thanks
Old 09-17-2007, 08:17 PM
HDF Tech Moderator
Pg 3 of the DTC chart....
232 is Loss of Tachometer Signal
242 is High Rate of Change Detected
Old 10-12-2007, 10:56 AM
AcidRayn AcidRayn is offline
okay, ive been having a problem with mine. so here goes.
o3 rkc
yes i have a service manual and can read/understand it, no, i do not have the electrical manual (loaned it to a friend?)
left on off switch has red power light
at first, it would work, come on, and then shut off for no reason
at times, it would work for a bit, then go off, kinda the problem was intermittent
now it wont work at all
i did the code check, im getting a 112 throttle roll off
i read the section on the CC, but, what should i look for? from my reading, i need to check the throttle cables and idle cable which comes from the cruise module? i need to check the module for oms, (im an electrical contractor, i have and know how to use the meter), and adjust the cable if needed?
things ive done since before it broke
i put on a seat, gently moved the cable plug under there to accomadate my new backrest
put on grips, (could throttle cable adjustment be affecting this?)
adjusted my handle bars, but cc not working before this
correct me if im wrong, o, please poor shovelheadbob, please guide me with your vast wisdom
Old 10-12-2007, 11:02 AM
Hdbiker1450 Hdbiker1450 is offline
I installed the cruise last May on our 02 RK. Works wonderfully well. However, while vacationing in the Gulf, we found that while the cruise is engaged, if you hit a rather large bump in the road, the cruise will automatically disengage. Not sure if this is a built in safety device or what.
Old 10-12-2007, 02:29 PM
oompa loompa
Old 10-12-2007, 07:25 PM
HDF Tech Moderator
Throttle Cable adjustment is more than likely the culprit....
Vehicles with Cruise have a different Throttle/Idle Cable adjustment.....
The cables need a bit more slack in them, due to the Roll-Off switch...
Old 10-13-2007, 09:41 AM
thanks bob, that is what i was thinking, but i did slacken both of them yesterday, and to no avail, cc is still not engaging.
so i guess im gonna just have to turn some wrenches today and find out what is the problem.
its driving me crazy, cuz i have nerve damage which causes my hands to go numb, and the cc allows me to relax my right as well as my left hands.
i'll keep yas posted on this
Tags
112, cable, clear, codes, control, cruise, dropout, dtc, harley, hd, idle, king, road, roll, sensor, throttle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
