Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Tech Forums > Electrical/Ignition/Tuner/ECM/Fuel Injection
Electrical/Ignition/Tuner/ECM/Fuel Injection Having electrical problems? Need advice on ignition issues? Questions about a tuner? Have questions about a MAP or Fuel Injection? Find your answers here.
Sponsored by: Phat Performance Parts
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-08-2009, 03:17 PM
leebrown leebrown is offline
Hang Around
Default I did a ohm test on the Set/Resume switch and it shows good
I can't get my indicator to turn green
Quote:
Originally Posted by jmetro View Post
Easiest way to check all dropout fucntions of your cruise control.
1. bike off, run/stop to run
2. push set/resume to set and hold.
3 with cruise on/off switch to on, turn on bike
4. cruise indicator light should be green, release set switch, light should turn red.
5. push to resume and release, light should turn green then red
6. push throttle closed and release, light should turn green then red
7. push rear brake pedal and release, light should turn green then red
8. pull front brake lever, light should turn green then red
9. on models with a clutch/neutral starter lockout, pull clutch lever, light should turn green then red
whichever switch does not turn the light green, is your bad one.
if light will not turn green at all and you have followed ALL directions and tried multiple times, your set/resume switch is bad.
If light stays green even after releasing set switch, one of the dropout switches is stuck closed, usually the roll off throttle switch. unplug this and try again.
make sure brake light will not turn on without using brakes (wobbly brake lever, stuck rear brake light switch etc.)
Happy hunting!!
P.S. this is really the easiest way to troubleshoot cruise control!!!!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 10-31-2009, 02:24 PM
jmetro jmetro is offline
Senior Rider
try leaving the run/stop switch to off, then turn the bike on holding the set/resume to set, then turn the run/stop to run while still holding the set switch. (sometimes this is ness on some picky bikes)
Old 11-01-2009, 05:05 PM
Kustomhd Kustomhd is offline
Hang Around
2003 Harley Davidson Electra Glide
Hey Acid Rayn I am a tech at our local shop and have seen your problem time and time again. If you are up for it I would change out you idle cable, the one this the 2 wires that go to it. This is most likely your problem just by reading your symptoms...
Tags
112, cable, clear, codes, control, cruise, dropout, dtc, harley, hd, idle, king, road, roll, sensor, throttle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
