Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Tech Forums > Electrical/Ignition/Tuner/ECM/Fuel Injection
Electrical/Ignition/Tuner/ECM/Fuel Injection Having electrical problems? Need advice on ignition issues? Questions about a tuner? Have questions about a MAP or Fuel Injection? Find your answers here.
Sponsored by: Phat Performance Parts
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 12-23-2008, 11:36 AM
cts1950 cts1950 is offline
Prospect
rahall
"I plan on making a couple of data runs for the purpose of checking the timing. My theory is that I will check areas where there are excessive anti-knock adjustments being made. I was planning on reducing the timing table in those areas. Does this make since?"
How are you finding your knock? By ear or by the log files. I found by using a o2 data log the knock was quite evident by watching the retard fast traces for the front and rear cylinders. I tried to increase my fuel to improve the problem with no great success. I ended up with my 4.89 gm/sec maxed out at 20 ms and 100% duty cycle and still knocking. I started reducing timing in the problem spots and seemed to make it worse. This is why I have the heads off again to remove any sharp edges that could be hot spots.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 12-23-2008, 11:37 AM
streetdjack streetdjack is offline
Hang Around
Yes, the Vtune process needs the ECM to stay in closed loop to complete.
That said, you can choose with the closed loop bias tables the "real" AFR value that the ECM will consider as 14.6:1
I might be wrong but when you set the CLB value to 750mV for ex, the ECM will go in closed loop for this voltage, thinking it's 14.6:1 and try to stay at it...
the ECM doesn't really know the AFR, all it knows is the value in mV that the sensors send to it... and we choose for it which voltage means 14.6:1
__________________
Member of The France StreetBob Forum : http://france-streetbob.superforum.fr/
StreetBob 2008
Arlen Ness Big Sucker, Vance & Hines Slip ons with quiet baffles, Andrews 26H cams
TTS Mastertune
Old 12-23-2008, 11:42 AM
Hang Around
Quote:
That's what I did too
but for me, decrease the spark advance in the area the knocking was detected, seems to have cure it
of course, my cams are OEM and your's aren't, that could be a reason
__________________
StreetBob 2008
TTS Mastertune
Old 12-23-2008, 11:46 AM
Prospect
Are you using the data master log viewing tool or another program to view the log files?
Old 12-23-2008, 11:57 AM
drod drod is offline
Prospect
I don't think this forum allows anything TTS.
__________________
'09 FLHX
TTS Mastertune w/Twin Scan ll+
___________________________
"there is nothing like a good tune"
Old 12-23-2008, 12:45 PM
rahall's Avatar
rahall rahall is offline
Senior Rider
I have not tried to do anything with the timing yet, but I plan on looking at the data.
I am not having ANY knocking or pinging problems after the TTS vtune.
But, I don't want to rely solely on the anti-knock system.
I would like to retard the timing where I see significant anti-knock system activity in the data.
As for the forum and TTS.
I don't believe that HDFourms has ANY problem with the exchange of technical information on TTS.
There are rules for selling things on HDF and some folks were not following them.
__________________
2007 Ultra Classic - Vivid Black
Hello from Alabama
Rineharts Slip-Ons, Vance\Hines Dual Headers, & K&N A/C
Head Quarters Cams, TTS Mastertune
Old 12-23-2008, 01:08 PM
yso191's Avatar
yso191 yso191 is online now
Senior Rider
I'm still in the 'TTST 100' class so to speak. I have done a couple of short V-tune runs, and the bike runs very well with one exception: popping on decel.
I found this in the manual:
"The VE table will affect the mixture during the entire decel event. To eliminate the popping, increase the VE setting in the first column (1 percent throttle) between 1750 and 3500 RPM by 5 to 10 percent. Some experimentation here will find the sweet spot that eliminates the popping."
I did one 5% with no effect, then another 5%... But it has been snowing and temperatures in the single digits since so I have not had a chance to try out the second adjustment.
Can't wait to take it for another run to see how it works. If it doesn't, I'll be back here asking questions.
I do have a question about AFR. I set the Closed Loop Bias Tables to 778 in order to get an AFR of 14.45. I'd like to go a little richer... like 14.2 eventually, so the CLBT would be set to 803 according to the O2 calculator. Am I missing something here? Streetdjack says in a recent post that 796=14.2:1. In Doc's V-Tune outline I got from someone, it says 680=14.5:1. But when I calculate it 680=14.63:1!
Is this difference due to bike/map differences?
Steve
__________________
2008 Super Glide
SE A/C backplate with Zippers Max-Flow filter, Vance & Hines slip-ons, TTS MasterTune, Amsoil 20-50 in everything, Boyeson X-wing, Microtach, Street Bob mini-apes from Rounder, SE 180 rear tire, Superbrace, True-Track
Old 12-23-2008, 01:39 PM
Hang Around
that's what I do ... I don't have anything else to use than the datamaster...
to Rahall : I'm exactly like you, no knocking problem but I hate to see anti-knock system activity in the data....
so I made some mods in the spark advance tables and it seems to cure it...
to Yso : I also had some popping on decell and had to increase the VE 10 units front and rear between 1500 and 4000 rpm in the 0 and 2 % colums to cure it... now it's nearly totaly gone (nearly ...)
The manual states not to go in CLB value more than 798mV (about 14.2 AFR) in the Tuning comments and information... that's where I'll stop
I don't think it's a problem of difference between maps, just too little difference between 803 and 798 mV ....
Doc was a little out when estimating 680mV to 14.5:1...
__________________
StreetBob 2008
TTS Mastertune
Old 12-23-2008, 02:09 PM
Prospect
I have been using the megalogviewer for a year or so. I started with it when I was using the DTT ecm and trying to understand cause and effect. It will allow you to look at 12 lines of data of your choice and zoom in on specific points It can be used to look at tts data also. You can see the knock on the green trace on bottom of the graph. You also can see many of the other paramiters that I was looking at the time the knock was occurring. Keep in mind I was not able to hear this but the ion sense was picking it up.
Old 12-23-2008, 03:08 PM
Steve Cole Steve Cole is offline
One thing users need to know is the HD system first then understanding knock will be much easier. The system is not there to tune the spark yet to stop the engine from knocking. What this means is it will do what it can too stop knock as quick as it can event if that means more spark is removed than necessary. Remember this is a safety device, so safety first then performance. The system reports what it see's, so you need to remember this is after it has already happened. So when you look for knock retard on a datamaster recording locate the first spot it happens and understand that it really happened just before that. This means you will need to look back a few frames of data to see where the engine was operating at to find the spot to apply a correction.
Tags
calibrations, cams, dtt, dyno, harley, headquarters, map, mastertune, mt7, table, thread, tmax, tts, ttst, tune, ve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
