Electrical/Ignition/Tuner/ECM/Fuel InjectionHaving electrical problems? Need advice on ignition issues? Questions about a tuner? Have questions about a MAP or Fuel Injection? Find your answers here.
That looks like the right file. If you go here: http://www.kuryakyn.com/index.cfm/go/Home.Cat/catID/15 Mike Roland and company have posted a multitude of MT7 files. That's where I found mine - you might luck-out and find exactly your setup. Less VTuning when the base is closer...
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
__________________ 2009 FLHR - Vivid Black Kuryakyn Crushers SE Stage I TTS
ctwith3 the PZ176-002-B1 file is for 07-09 Touring bikes with o2 sensors. Your 2010 FLSTF with intake and exhaust could start with the AF176-002-B1 file then go into the ECM tuning constants and lower the Eng. displacement back to 96.7.
I'll load that AF176-002-B1 file and start from there.
__________________
2010 Fat Boy with Chrome Wheels, Vance & Hines Big Shots Staggered, Zipper's Max Flow air cleaner with chrome backing plate, TTS Master Tune, and more chrome than my wife wanted me to spend money on
Hey ColdCase, can you help me out with my post #1021 above?
I think the various approaches get you to the same end result, but using Doc's shortcuts may get you more cells covered with real data quicker. I basically did what others have said, read a bunch of manuals and posts and put together a simplified cheat sheet. I'll see if I can find it tonight, but it was based on manuals a couple revisions old. Perhaps Doc's tricks have been incorporated into the latest manuals.
I think the only thing that really makes a big difference initially is what you use for the CLB offset. You pick a number going in, if later you want to experiment with another offset, you start VTune from scratch.
The penalty is just time, but if you don't have much time that could be frustrating.
Good news- I brought home a laptop from work and ran a VTune.
Bad news- the battery died after only 19 minutes.
__________________
__________________
