Electrical/Ignition/Tuner/ECM/Fuel InjectionHaving electrical problems? Need advice on ignition issues? Questions about a tuner? Have questions about a MAP or Fuel Injection? Find your answers here.
Post which map you are running with your PCIII or SERT and Mod's
Quote:
I added SERT to this thread too to see if we can get some more maps on here
I am looking to see what maps people are running on their PCIII and what mods they have with there bikes. I have been downloading some maps and comparing the values to see what is happening.
When I got my PCIII it had the map 807-213 loaded into it which is for a stock ECU with Vance and Hines oval slip on and a Screaming Eagle air filter. The bikes runs awesome...BUT
My bike is a 2006 RK Custom with a Stage 1 download in the ECU and Screaming Eagle slip ons 64903-99 slash down and the Screaming Eagle air box 29773-02B. I am looking to download another map for a stage 1 ECU and my mods. My bike turns over 5 or 6 time before it fires now and use to be instant. I am looking at the Power Commander site to see what they have. They are closed on the weekend for phone help.
Thanks for any info.
Neil
I have downloaded map M807-152 into my bike to check it out from the Power Commander site. It is for Vance and Hines oval slip ons, screaming eagle air filter and stage 1 ECM. It was pretty straight forward. Pulled my PCIII and brought it in seeing how I don't have a laptop here. Plugged in the 9 volt battery for power and hooked it up to my USB port. I had the PC software open and it seen the unit and uploaded the map. I selected the new one and hit send map. Now for a little road time and check it out. Tomorrow I will hook a laptop up and check out some other stuff like throttle position.
Later on
Neil
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
__________________
Laid back in TN
06 RK Custom "gone"
07 Big Dog Bulldog
RE: Post which map you are running in your PCIII and Mod's
I am running 807-164 (2005 with Rush pipes 2.5 baffle, SE Air Cleaner, and Stage 1 ECM) I sent an email to Dynojet and the suggested the 807-213 but it popped on decel and didn't seem right. The 807-164 is better in my opinion. I plan on having it dynoed this spring. My mods are
Stage 1 download, SE air cleaner, and V&H Basic Slip-on pipes on an 06 Roadglide.
I have a 06 RK Custom with SE air cleaner, SE slip ons and a stage 1 download. I had been running the M807-152 map but have chaanged over to the M807-159 which is for 2005 Harley Davidson Touring Model Samson rolled oval slip-ons ,Screamin Eagle air filter, Stage 1 ECM. Bike runs good.
Today I download the Free Accelerator pump program from the Power commander site and loaded it into my PCIII USB. Pretty cool piece of software. Alows you to set your throttle response to fuel to take out any hesitation. It is only available for the USB model PCIII
Neil http://www.powercommander.com/accelpump.shtml
__________________
Laid back in TN
06 RK Custom "gone"
07 Big Dog Bulldog
Update:
I just calibrated the throtlle and now it is running way to rich at idle and when I crack open the trhottle. I only let it run a few minutes. Am going to try to take it for a spin tommorow and I hope it clears up when the engine gets warm
__________________
06 Fatboy Wild 1 12.5 Apes
Chromed out Handlebars
V&H BSS with PC V
Custom Fender Bib by Sundog Leather
RE: Post which map you are running with your PCIII or SERT and Mod's
I am using map 141NX104 within the HD SERT Rev E. The bike has some minimal surging at approximately 1500-2000 RPM, otherwise it starts and runs fine. I am re-reading the SERT manual so I can figure what changes are needed to the base line to correct the surging.
If anyone has a SERT map available for my configuration, please help. Thanks!
2006 FXDBI (Street Bob)
SE II Slip ons
SE Aircleaner/filter
Stage 1 ECM
i run 89 octane
I've tried several maps, but i'm currently running a modified version of M810-036 until I have the $$$ to get it dyno-tuned.
