Electrical/Ignition/Tuner/ECM/Fuel InjectionHaving electrical problems? Need advice on ignition issues? Questions about a tuner? Have questions about a MAP or Fuel Injection? Find your answers here.
RE: Post which map you are running with your PCIII or SERT and Mod's
currently running map # 807- 162 as per dynojet..... also using the pump accelerator feature i think that it may be running a little rich with this map. i pulled the plugs and they look kinda black & sooty.... bike only has about 3800 miles the following is my setup
05 classic
wildpigs slipon's 1 3/4" baffles
ness big sucker a/c
stock ecm
pc111 usb
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
__________________
Reece
05 Ultra Classic
Wildpigs slipons 1 3/4" baffels
Ness big sucker
PC111 USB
stock ecm
Fullsac true duel conversion
I have a 2006 street glide and I am running the bassini slip ons with SE air filter and stock ecm any suggestions on what map to use also I started at a stock configuration and got a check engine code ??
I would like to find more SERT maps,too. I am just in the ball park with my combination of mods to the motor . 04 Deuce . 95 flat tops , 039 headquarters cams s&s gear drive , Shortblock Charlies-Scottsman heads , roller rocker . a few different pipes . tech lussion box and 51 mil throttle body with intake . anyone got some maps not in the list on the race tuner software I can try before I go dyno. thanks
I am running the Dynojet Canned map 807-167 right now, and I'll bet getting to a dyno sometime this month to see if anything needs to be changed.
'05 Touring
stock motor
stock ecm
Ness Big Sucker
Thunderheader 2-1
PCIIIusb
It runs great now, no hesitation, no loading up, and the milage is around 40 mpg. I just want to make sure I have a good AFR and see if anything can be tweaked to make any more power.
Steve
__________________
---------------- 2005 Harley Davidson FLHTCUI Ultra Classic
Powered by Big Boyz Heads, Woods Cams, Doherty A/C, TTS, Fatcat, Hillside TB
Built by Me, Tuned by Bean
I'm using 807-173 and have big sucker and an ST with 7 disks and an open end cap.
Haven't dynoed yet waiting for more, like a geared cam and who knows. A zippers kit or Gmr 98 inch.
But will have to wait for winter now!Its 80 out there!
I have ditched the PCIII and purchased a SERT instead due to slow starting with the PCIII on my 06 RK Custom.
I am running calibration #55 with a stage 1 A/C and SE slip on mufflers. The bike is running awesome.
I am going to install so true duals soon.
Neil
__________________
Laid back in TN
06 RK Custom "gone"
07 Big Dog Bulldog
Quote:
ORIGINAL: dashiell
06 Flstci
SE Air Kit w/K&N Air Filter open with a chrome smoothie end cover
SE II Pro Slip-ons
25 Degree Fuel Injectors
Sert 141NP001 w/3.91 Tuning Constant
Amazing. This map is not even listed in the latest SERT manual in section 9 but it is on the disk. This is the best map I have tried so far.
2006 Softail Deuce FXSTDI
K&N Air Cleaner
V&H Big Radius pipes
8 deg injectors (part number 27625-06)
'06 Wide Glide
SE AC with KN filter
Samson Street Sweepers
Running a custom SERT map I made myself.
If anyone needs a map for an '06 Dyna running SEII exhaust (or custom exhaust) and SE/AC then PM me and I'll send some maps your way. I've got good feedback from a bunch of Dyna owners running them. You might be surprised at how much better the bike runs with a decent map.
