Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Do It Yourself Help Forum > Electrical and Lighting
Electrical and Lighting Tips on everything electrical and light systems.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 01-31-2009, 08:59 PM
Harleypingman's Avatar
Harleypingman Harleypingman is offline
Graeme, thanks for the write-up and pics. A couple of suggestions that have worked well for me:
1. Cover the front fender with something that will protect the paint if a tool, screw, or, heaven forbid, the fairing is dropped.
2. Cover the passing lamps, if you have them, with atheletic socks to protect the paint--when the fairing is removed, it's a bit of a tight fit getting past the passing lamps.
3. Start by loosening the three windshield screws, then remove the windshield and set it aside.
4. If you have windshield trim (I have the HD stainless Bar & Shield), remove all three screws and remove the trim piece.
5. Reinstall the the center screw--it will hold the fairing in place while the four screws on the inner fairing side are removed.
6. Loosen the center screw to the point where it can be removed by finger action, then put the tool used in a pocket or to the side (I'm not sure-handed enough to hold a wrench, etc. in the hand while removing a screw and holding the fairing while I reach in to unplug the headlamp plug.)
7. Support the fairing below the headlamp with one hand, use the other hand to remove the center screw, pull the fairing away far enough to reach behind it to unplug the headlamp plug, then remove the fairing and set it aside where it won't be damaged.
I prefer to use a T27 drive rather than a ratchet; lighter and smaller which is helpful on the bottom two screws.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
CMA, Crossties Chapter (GA)
IBA 26580
'04 FLHTPX
Old 02-01-2009, 02:05 PM
swlamedic's Avatar
swlamedic swlamedic is offline
Prospect
2007 Harley-Davidson Ultra Classic Electra Glide
Send a message via Yahoo to swlamedic
Thanks a ton!!!! Now that I see how easy it is, I am going to look into those Hogtune speakers. The factory ones have a lot of distortion, and my wife says she can not hear the ones in the back. Do you plan on showing how to replace the rear speakers? Also, would it be possible to add a small 40 or 80 watt amp to this system without having to replace the head unit? I replaced my entire truck with Alpine, but I like the factory radio on my bike.
__________________
"Fifteen grand and fifteen miles don't make you a biker."
swlamedic's Avatar
Prospect
Never mind, I just saw your next thread about the amp.
__________________
Old 02-13-2009, 07:13 PM
Richpend's Avatar
Richpend Richpend is offline
Senior Rider
Good job!!
__________________
Rich 08 FLHTCU Vivid Black S/E Stage 1 A/C
V&H Ovals Slip-ons Detach Tour/Pac
http://i313.photobucket.com/albums/ll380/richpend/DSC00092.jpg
Old 02-18-2009, 07:49 PM
livefreeordie livefreeordie is offline
Hang Around
Great post!
I'd like to get my inner fairing painted, instead of buying a new painted one, but removing all the gauges is over my head. I called the local dealer and they estimate the labor at 2.5 hours (~$200), assuming they replace the stock inner fairing with a painted one (~$425). Have you considered posting removal of the inner fairing?
Steve
2005 Classic Glide
Old 02-19-2009, 11:54 AM
dawg's Avatar
dawg dawg is offline
Quote:
Originally Posted by livefreeordie View Post
Great post!
Steve
2005 Classic Glide
It's easy to remove the inner. I see your name is livefreeordie, does that mean you are from NH? If so I'm right on the Lebanon NH border and would be more than happy to come to your place and help remove it. I removed mine in about an hour or so, same with the reinstall.
__________________
'08 105th anniversary Ultra
D&D Fatcat
Zippers Redshift 575 cams
EVO Ind. 30 tooth
SERT
www.vtroaddawgs.com
www.roaddawgs.com
Old 02-20-2009, 12:11 PM
GasCan GasCan is offline
Inner removal is pretty straight forward. Just be sure to mark connectors when you take them off and note where each gauge goes and have at her.
Old 02-20-2009, 12:48 PM
Hang Around
Thanks. Dawg is going to stop by to point me in the right direction.
Old 02-20-2009, 01:02 PM
checkers checkers is offline
Prospect
man! outstanding right up and pictorial. good stuff. would like to see more of this kind of stuff on the forum, very helpfull for future mods. thx
Old 03-20-2009, 07:22 PM
ultraherbie ultraherbie is offline
Hang Around
great, loved the pictures. Is there a way to save these instructions?
__________________
08 Ultra 105 annv.
SE air filter
Rineharts
Power commander 111
Fast Aire 10" tinted
87 BMW R80RT
82 Yamaha 750 Seca
Tags
1994, 2007, 2008, batwingfairing, covering, davidson, fairing, harley, made, outer, removal, rubber, seals, speaker, ultra, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
