SE Stage 1 Air Cleaner Cover?
Old 07-11-2011, 01:32 PM
BCKNBLK's Avatar
BCKNBLK
BCKNBLK is offline
Default SE Stage 1 Air Cleaner Cover?
Hi guys,
I got a SE Stage 1 part number 29773-02C (round air filter) for my 2010 FXDC. According to the Harley website it says it can be used with any of the decorative air cleaner cover collection but when I look at the filter I only see the hole in the center but the air cleaner covers on the website for Dyna's don't appear to have the bolt pattern for the SE kit I bought. Can I still use the stock cover with the kit I bought?
What have you guys used for air cleaner covers for the open air round filter? I wanted to try and get away from the stock cover but apparently Harley's website is a bit misleading when it says the kit can be used with the air cleaner covers from the decorative collection.
Thanks in advance!
Bruce
Old 07-11-2011, 03:21 PM
guff's Avatar
guff
guff is offline
I believe the air cleaner covers come as a "kit" with the mounting bracket and bolts...
http://www.harley-davidson.com/en_US...ts/-J03315.pdf
Old 07-11-2011, 03:40 PM
BCKNBLK's Avatar
BCKNBLK
BCKNBLK is offline
That part number says "fits evolution 1340 and twin cam equipped models with stock air cleaner (except 08 and later Dyna)" Don't think it will work. When I do a search on my model the only air cleaner trim cover that shows up don't have the bolt pattern that the kit I have has.
I think I am just going to exchange it for kit 29406-08 which is used with the stock air box and order the air cleaner trim cover I want. Seems to much of a hassle to try and find one I like that fits the open air SE Stage 1.
Old 07-11-2011, 03:41 PM
PMB3's Avatar
PMB3
PMB3 is offline
Ramones CD
F86 (12-03-2017)
Old 07-11-2011, 05:27 PM
rooti's Avatar
rooti
rooti is offline
check out the dyna classifieds on this site. I guy has a cover for sale and you can see the way it mounts
Old 07-11-2011, 06:49 PM
coop creek's Avatar
coop creek
coop creek is offline
29773-02C, that's the SE high flow ac kit with a round filter, right? There are lots of ac trim rings that have center holes to attach to your filter. I'm not sure what you are looking at. Go to Drag Specialties or similar and pick out a cover you like. This is what I did. This is the same ac kit that you have but the backing plate is chrome, the filter is a K&N substitute. The cover is Pro-One, 5.485" diameter.
Attached Thumbnails SE Stage 1 Air Cleaner Cover?-ac-cover-002-medium-.jpg   SE Stage 1 Air Cleaner Cover?-ac-cover-medium-.jpg
Old 07-11-2011, 07:02 PM
jack0890's Avatar
jack0890
jack0890 is offline
Default SE Stage 1 A/C cover
Don't know what you're looking for exactly but HD has the smooth air cleaner cover (just a basic round chrome cover) part number 29153-07 which will fit the kit you bought. Also I don't know the part number , but the stock cover off of a Crossbones will fit also. It's the same as the chrome one but it's black. Never mind just found it. The black one is p/n 29400-08. These are just basic round covers though, so I don't know about anything decorative. Or you can swap it for 29406-08, which uses the stock teardrop cover on bike. Hope this helps.
I believe the 29406-08 converts the stock cover to an open air element like the round one, but not sure. Been looking myself, but hadn't decided which way to go yet. I just noticed you were the one talking about swapping it for the other kit to fit the stock cover.
Old 07-11-2011, 08:15 PM
ZeroFiveFour's Avatar
ZeroFiveFour
ZeroFiveFour is offline
Bro,
DONT GIVE UP. It is simple to get the set up you want...
I have the same set up you are trying to go with.
It is so simple..
1: keep the se air filter back plate you have, part number 29773-02C
2: get the air cleaner insert, part number 29417-04 (COMES WITH mount adapter, 5 minute install).
http://www.harley-davidson.com/gma/g...bmLocale=en_US
3: You are good to go.
pm me if you need any install help or other assistance finding the right parts etc...
Here is a few pics of my bike with the set up...
Cheers,
Tom
Old 07-11-2011, 09:08 PM
coop creek's Avatar
coop creek
that is a "Derby style cover" that has 5 screws around the perimeter. There is a starfish shaped adapter that fits between the filter and the cover. It has a center hole to attach to the filter and 5 arms to attach to the cover screws, comes with the cover as noted in the above post.
Old 07-11-2011, 09:15 PM
BCKNBLK's Avatar
BCKNBLK
BCKNBLK is offline
Originally Posted by ZeroFiveFour
Bro,
It is so simple..
Cheers,
Tom
That looks great! I will head to the dealer tomorrow and order that cover. That was my second choice behind the flames cover. Thanks! It wasn't clear that it works with that SE kit number so that's why I wasn't sure - now that I have seen pics and know it works that is all the proof I need. Thanks again so much!!
Cheers!
Bruce
Quick Reply: SE Stage 1 Air Cleaner Cover?
