Screaming Eagle air cleaner kit for Super Glide Custom
Old 02-13-2011, 08:48 PM
superglideguy's Avatar
superglideguy
superglideguy is offline
Question Screaming Eagle air cleaner kit for Super Glide Custom
Has anyone had a Screaming Eagle air cleaner kit (Heavy Breather or Ventilator) kit installed on a newer Super Glide / Custom? Any information/pics would be appreciated. Also, did you upgrade your pipes at the same time?
Old 02-13-2011, 09:00 PM
aclundwall's Avatar
aclundwall
aclundwall is offline
I have the SE ventilator on my new Superglide. Here's a crappy pic of it. But I can't really comment on what kind of difference it makes, because I had that, the stage II 103 kit, and the V&H exhaust added when I bought the bike. All I can say is that I like the way it looks, and I like that it doesn't stick out a whole bunch.
Attached Thumbnails Screaming Eagle air cleaner kit for Super Glide Custom-fxdc.jpg
Old 02-13-2011, 09:12 PM
bberck's Avatar
bberck
bberck is offline
I had the heavy breather on my Super Glide and liked it alot.
I had slip-ons on the bike then added the Heavy breather and PCV. I later switched to a D@D Fatcat exhaust.
Old 02-13-2011, 09:24 PM
superglideguy
bberck: Did you install yourself or have it installed? How much is involved in the ECM calibration for the EFI? How much improvement did you see with performance. Also, can you only use it with stock pipes to be street legal or did I dream this up?
Old 02-13-2011, 09:37 PM
bberck's Avatar
bberck
bberck is offline
I installed it myself and there isnt much to it. I used a PCV for the EFI and its a easy install as well. I added the breather and PCV at the same time so i noticed a nice improvement in both performance and the bike running cooler.
As far as street legal it probally doesnt take much add -ons for a bike to no longer meet epa guide lines so that may be true but I have no idea.
Old 02-13-2011, 09:48 PM
superglideguy
Default SScreaming Eagle air cleaner kit for Super Glide Custom
Thanks guys for the info and pics. I think there cool and will invest in one.
Old 02-14-2011, 10:09 AM
T.o.n.y.T.'s Avatar
T.o.n.y.T.
T.o.n.y.T. is offline
I was thinking about getting the SE Air Cleaner, but ended up going with the Kury Velociraptor stack. Love the way the SE's look though.
Old 02-14-2011, 08:08 PM
superglideguy
bberck: Dumb question but what does PCV stand for? I asked the dealer for the cost of the breather and installation. They informed me that I of course also had to go with slip on SE pipes/tuner and also perform the ECM calibration for the EFI. The total is almost $1400. Any ideas for going less expensive?
Old 02-14-2011, 08:16 PM
fjm3rd's Avatar
fjm3rd
fjm3rd is offline
PCV Stands for Power Commander 5. V roman numeral for 5
Old 04-19-2011, 07:46 PM
Gregorycoz79's Avatar
Gregorycoz79
Gregorycoz79 is offline
1st Gear
bberck: I installed the se kit and have a wire that connected to stock air cleaner and nothing to connect it to. the directions don't mention this wire. What did you do with it. I have a 2010 wide glide.
Thanks
Quick Reply: Screaming Eagle air cleaner kit for Super Glide Custom
