Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Dyna Glide Models
Dyna Glide Models Super Glide, Super Glide Sport, Super Glide Custom, Low Rider, Street Bob, Fat Bob and Wide Glide.
Sponsored by: True-Track Inc.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 11-03-2009, 01:20 AM
lhcstreetbob's Avatar
lhcstreetbob lhcstreetbob is offline
Senior Rider
mine is doing the same thing.. if i dont start it right away it takes a few times to make it start. its very annoying i would like to see if there is a way to fix this
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
2008 FXDB ,pcv thunderheader ,Big sucker, progressive 412, progressive fork springs ,various powdercoat including 2007 triple trees
Old 11-03-2009, 01:58 AM
arnold's Avatar
arnold arnold is offline
Mine was sort of hard start after the initial PCIII install but now like most I just turn ignition on and fire it up, almost always hits instantly. Before PCIII I waited just to hear the fuel prime but that isn't needed anyway they fire on command, one of the nice things about EFI, fires right up in 20 degrees with no foolin around
__________________
2008 Harley-Davidson FXDF Dyna Fat Bob
Thunderheader Big Sucker A/C
PCIII USB Custom advanced map from fuel moto
Barnett Heavy Duty clutch spring
Anarchy is only truly fun for the rational anarchist
Old 11-03-2009, 11:14 AM
fuelmoto's Avatar
fuelmoto fuelmoto is offline
Platinum Sponsor
I would recommend checking the throttle position settings with the PC software as a starting point.
__________________
Jamie Long / Fuel Moto USA
For the Fuel Moto forum section go here http://hdforums.com/forum/fuel-moto-137/
The USA's Leader in EFI Performance www.fuelmotousa.com www.jackpotmufflers.com
Contact 877-729-4754
Email jamie@fuelmotousa.com
http://fuelmotousa.com/fuelmotoheader.jpg
Old 11-03-2009, 01:38 PM
jcannady jcannady is offline
Hang Around
Quote:
Originally Posted by jeff.georgalas View Post
A+ on this. I was having the exact same problem. Talked with Jamie @ fuelmoto, and he explained this to me, and the technical jargon that goes with it. I forget the exact explanation, but he told me to just start it right up after the ignition is turned on, and he guaranteed me that this will not hurt the bike in anyway. I've been doing that ever since then, and no problems at all, and it cranks right over every time! If there's anybody here who's advice that I trust it's Jamie's, so I'm doing as he suggested.
I'm a little confused on this. When I crank my SB I turn the key to ignition, press the run switch, and then press the starter button. Is there a different order that I'm missing?
Jim
Old 11-03-2009, 01:50 PM
redlohsom's Avatar
redlohsom redlohsom is online now
Hang Around
Quote:
So what is it Jamie?? check TPS with software or Just let it be and start it up with out waiting?? someone quoted you on here. Mine is doing the same thing.
__________________
"Old Sarge"
2008 Dyna Street Bob
2" risers
103ci "Big Bore" Kit
V&H B.R. 2-2
PC-V
Old 11-03-2009, 02:23 PM
fuelmoto's Avatar
Platinum Sponsor
Quote:
There are a couple different things being discussed and one bike in the discussion is a 08 touring model which has a different EFI system. As I recommend I would first check the throttle position settings with the PC software because if this is off a couple % it will shift the entire map and can affect starting. If you check/reset this and its OK and you still see a slight starting delay it can due to the way the PC unit boots up and any delays can be alleviated using the following starting procedure which are not related to the map or start up fuel that some have recommended using. When starting the bike turn on the ignition switch and press the start button immediately, you do not need to wait for the engine light to go out. There is no reason to wait for the light to go out, it is not in the owners manual under "Starting your motorcycle" and this is likely the same procedure you use every time you start your car. There is fuel pressure at the injectors and when you hear the pump running it is on a clock which shuts it off after several seconds not fuel pressure. The starting delay some are seeying in most cases is almost immeasurable, however using the procedure works the best. If anyone needs any help just let us know, we are here to help.
__________________
Old 11-05-2009, 09:46 PM
Hang Around
Just to let everyone know, both approaches worked. I pressed the start button before the engine light had gone out and it started right up. I then went into PCV and reset the TPS. Now, even when I let the engine light go out it starts right up.
Thanks again!!!
Jim
Old 11-05-2009, 11:05 PM
FXDCme's Avatar
FXDCme FXDCme is offline
Hang Around
My TPS is at 5% when it should be at 0%. How do I reset it?
__________________
The happiest people don't necessarily have the best of everything; they just make the best of everything they have
Tags
codes, commander, dyna, glide, harley, power, reviews, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
