Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Dyna Glide Models
Dyna Glide Models Super Glide, Super Glide Sport, Super Glide Custom, Low Rider, Street Bob, Fat Bob and Wide Glide.
Sponsored by: True-Track Inc.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-17-2009, 09:30 AM
FXD2003Rider's Avatar
FXD2003Rider FXD2003Rider is online now
Senior Rider
Arrow ***dyna models metric sizes database***
Occasionally forum members have questions on what size of metric tools they have to use on the metric bolts and nuts mounted on their dyna model.
Info on this subject is scattered in the forum now.
Purpose of this thread is to gather this info and put it in an easy accessable database.
Any suggestions and additional info from your side is appreciated. Just add a posting to the thread and I'll process the info into the database.
Thanks in advance,
___________
FXD2003Rider
Link to general info on ISO metric screw thread and wrench size in mm
2003 FXD
battery terminal bolts p/n 4312 (M6 X 1.0 X 12 flange head)..................... 10mm 6-point socket added 10-19-2009
clutch spring / pressure plate bolt M6 X 1" X 16 hex head, p/n 2980 .......... 10mm 6-point wrench/socket (added 11-04-2009) contribution of: mud (link)
fork tube cap p/n 45996-87 .................................................. ............. 35mm 6-point socket
35mm forks cap nut socket tool link
front axle nut p/n 7956 .................................................. ................... 19mm 6-point socket
front brake caliper lower mounting bolt p/n 44160-00 ............................... 10mm 12-point socket
front brake caliper upper mounting bolt p/n 44163-00 .............................. 10mm 12-point socket
front brake master cylinder fitting single disk p/n 41739-84A ..................... 11mm 12-point socket
horn/horn bracket nut M6, p/n 7495 .................................................. .. 10mm 6-point hex wrench/socket (added 11-04-2009) (link)
rear axle castle nut p/n 7987 .................................................. ........... 24mm 6-point socket
rear brake caliper bridge bolt p/n 44177-00 ............................................ 10mm 12-point socket
starter motor section:
NUT, flange M8, p/n 3403 .................................................. ................ 13mm 6-point hex wrench/socket (added 11-04-2009) (link)
BOLT, starter M5, p/n 928 .................................................. ................. 8mm 6-point hex wrench/socket (added 11-04-2009) (link)
SCREW w/ O-Ring M4, p/n 929A .................................................. ......... 7mm 6-point hex wrench/socket (added 11-04-2009) (link)
2005 models
front fork seat pipe screws p/n???? .................................................. . 12mm 6-point allen wrench added 10-20-2009 contribution of: jmpancoast (link) &
FastHarley (link)
2006 All models
2007 FXDC
fork tube cap p/n 45996-87 .................................................. ............. 35mm 6-point socket contribution of: 2007fxdc
fork tube spring asembly socket head bolt
p/n 46614-06 Bolt M14 x 1.25 x 30socket head ....................................... 5mm 6-point hex bit added 10-20-2009 contribution of: thedonthere (link)
front axle clamp hex button head bolts p/n 4042 ..................................... 5mm 6-point hex bit added 10-20-2009 contribution of: thedonthere (link)
as a companion to this 4042 bolt we have p/n 7062 metric lockwasher M8.4 x 13 x 1.2 (added 11-06-2009) contribution of: mud (link)
rear axle nut p/n 8039 .................................................. .................... 28mm 6-point socket contribution of: rdondes (link) & SC-Longhair
2008 models
battery terminal bolts (flange head) p/n 4312c ...................................... 10mm 6-point socket added 10-19-2009 contribution of: frogg (link) & BBerck
Hex screws to the fork axle holder p/n4042 ............................................ 5mm 6-point socket contribution of: BBerck
jam nut on the clutch pack is a M17 bolt p/n??? ................................... 17mm 6-point socket contribution of: maddghost (link)
Fatob rear axle nut .................................................. ........................ 36mm 6-point socket contribution of: archergodwin (link)
rear axel nut p/n's:
7813A axle nut for WG, SGC, SB and LR if has spoke wheels contribution of: BBerck
8020 axle nut for SG, FB and LR with mag wheels contribution of: BBerck
FXDC rear axle hex head p/n??? .................................................. ...... 28mm 6-point socket contribution of: archergodwin (link)
Showa forks
fork tube (l&r) damper (socket head) screw p/n 46614-06 ....................... 12mm 6-point socket head contribution of: 2007fxdc; SC-Longhair; BBerck
1/2" Impact Socket head 12 mm metric Hex Driver tool link .................................................. ....... contribution of: SC-Longhair
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 10-17-2009, 10:43 AM
2007fxdc's Avatar
2007fxdc 2007fxdc is offline
Rene', why limit it to metric sizess? Unless there is already a database for the U.S. sized parts.
I can add two but I don't know and don't know where to find the part numbers. On the Showa front forks of my 07 FXDC, the seat pipe screw is 12mm hex. That tool doesn't seem to be found commonly in hex kits you buy retail. Some of us have purchased it separately at Sears for 8 bucks. Also, the fork tube caps are 35mm wrench or socket, preferably socket for removal.
__________________
2007 FXDC, SE 180 rear, Chromed FXD wheels, Mustang Tripper Solo, V&H Big Radius, Stage 1 Complete, Kuryakyn Extended Forward Controls, HD Chrome Front End Kit, Progressive 412 HD, Jackyl 2" Tank Lift
Old 10-17-2009, 11:14 AM
Senior Rider
Greg, your contribution is much appreciated! I've added the info on the tube cap to the database.
Quote:
Originally Posted by 2007fxdc View Post
Rene', why limit it to metric sizess? Unless there is already a database for the U.S. sized parts..
Most (US&UK) members do have a nice set of "Across Flats" (AF) wrenches and sockets in the tool-box and not so many "metric". Over here on the European continent it's the opposite. I started the database in order to determine what kind of "metric" wrenches are needed so you guys in the USA and UK are able to order/buy the single ones you need, instead of having to buy a complete metric set.
...on the Showa front forks of my 07 FXDC, the seat pipe screw is 12mm hex....
Not shure what you mean by the "seat pipe screw" ; could you be a bit more specific please?
As for the p/n's: I have them from my parts catalog
___________
FXD2003Rider
Old 10-17-2009, 11:34 AM
SC-Longhair's Avatar
SC-Longhair SC-Longhair is online now
2007 Harley FXDWG
I don't know the part number as its not listed in the 07 part manual but...
the allen bolt underneath the left side fork tube holding the damper in is 12mm 6pt...NAPA auto p/n:61-5312 http://www.napaonline.com/NOLPPSE/%2...312_0006572290
__________________
It has some stuff
You can call me Vic.
Old 10-17-2009, 11:42 AM
bberck's Avatar
bberck bberck is offline
2008 Harley Super Glide
Part number for the 12mm hex screw they are talking about is 46614-06
__________________
Chrome Moter Package, D&D Fatcat 2-1, SE Heavy Breather, PC5, C&C Seat, SE 180, FXDSE Bars, Bullet Headlight, Super Glide Battery Band, Turn Signal Visors, Side Mount License Plate, LED turn signals, HD Diamond Plate Pegs and Grips, ETC.
2007fxdc's Avatar
Yeh, what he said.
__________________
Old 10-17-2009, 11:51 AM
2007 Harley FXDWG
Quote:
Ty, BBerck.
__________________
It has some stuff
Old 10-17-2009, 12:06 PM
Senior Rider
Default new info added
Showa forks
left side fork tube damper (socket head) screw p/n 46614-06.......12mm 6-point socket head ** contribution of: 2007fxdc; SC-Longhair; BBerck
Like this, guys?
___________
FXD2003Rider
Old 10-17-2009, 12:18 PM
bberck's Avatar
Hex screws to the Fork axle Holder are 5MM Hex #4042
__________________
Old 10-17-2009, 12:21 PM
2007 Harley FXDWG
Rene' the p/n is for the screw itself. The p/n I listed is for a tool to extract it easily.
__________________
It has some stuff
Tags
07, 12, 4416300, axle, bolts, davidson, front, fxd, harley, hex, holder, metric, nuts, parts, point, wrench
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
