Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Dyna Glide Models
Dyna Glide Models Super Glide, Super Glide Sport, Super Glide Custom, Low Rider, Street Bob, Fat Bob and Wide Glide.
Sponsored by: True-Track Inc.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-17-2009, 01:28 AM
timberwolfz28 timberwolfz28 is offline
Default Axtell 107 kit...
In looking at engine mods, I ran across their package shown here:
http://www.axtellsales.com/items.cfm?ID=1494
the problem is, they don't list prices, and they are closed til monday.
Anyone know what this setup costs?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
BARE BONES OR SIMILAR SOLO SEAT WANTED...MESSAGE ME!
http://www.hdforums.com/forum/image.php?type=sigpic&userid=64393&dateline=121903  0425
Old 10-17-2009, 03:10 AM
kk6pg's Avatar
kk6pg kk6pg is offline
Axtell is a fast grand plus in parts alone for the barrels and pistons. The nice part is, its the best that money can buy.
__________________
08 Superglide Posercycle
With a bunch of useless stuff that makes me think I look cool
08 XL1200 Low 105th (for mama)
Just because the design is 100 years old, doesnt mean there hasnt been a few improvements
Old 10-17-2009, 08:08 AM
PitDog's Avatar
PitDog PitDog is offline
Prospect
if you've got a 07 or up with 4.375 crank you can have your stock cylinders bored to get your 107ci. if your bike is older you can still go to 98ci. but to get a 107 on a pre 06 bike your cases will have to come apart and spigots bored. call scott at hillside cycle, they have pistons for a 107 that use stock bored cylinders.
__________________
C-Cat
Old 10-17-2009, 09:06 AM
redrubicon2004's Avatar
redrubicon2004 redrubicon2004 is offline
2004 Jeep Wrangler
My Garage
Axtell actually just sells a piston, jug and gasket set. Its part number 200-300 For black. I believe it $1169.95 at least that is how much it was last year.
I am going to be buying this kit later this year for a winter build. Like it was said above, this is the best 107" on the market. The OP has a 03 so he needs to bore his cases to go 107" on a stock crank. I will warn you though. Have the crank trued and welded while it is out for case boring. Also make sure you do the timken bearing upgrade. Both will be needed to keep the bottom end together with a 107". I was told the 03's still have forged cranks, so its worth putting money into the stocker to save it.
__________________
-Chad-
95", ported heads-1.9 int 1.625 ex, 37G cams, SE cam plate and pump, Welded crank, Timken bearing, 42mm Mikuni
Old 10-17-2009, 10:11 AM
What should I expect to spend on case boring and the work on the crank?
I plan on heads too... anyone used the Baisley heads they mention? price on those?
RedRubicon... do you plan on keeping your 37G cams? I have to double check what the indy used, but I think I have 37B in mine...
__________________
Old 10-17-2009, 12:03 PM
thedonthere's Avatar
thedonthere thedonthere is online now
I bought their 97" kit for $460.00 exchange. Part of my winter mods this year.
__________________
2006 FXDBI / Andrews 37H
Head Designs By Dewey / 1.90 intake / 9.4:1
Tune by American VTwin Services / PCV
Rinehart 2-1 / 92hp 95ftlb / still 88ci
"The United States is a nation of laws: badly written and randomly enforced." - Frank Zappa
Old 10-17-2009, 12:22 PM
yso191's Avatar
yso191 yso191 is offline
Senior Rider
Excuse the thread hijack, but I am researching a big bore kit also. What makes Axtell better than say the SE big bore kits or others? And then the next question is, is it worth the price difference?
For example I am watching a SE 103 kit on ebay that has jugs, pistons, rings, cams, and clutch spring for $550. No exchange.
No agenda or conclusion on my part, I ask to learn.
Steve
__________________
2008 Super Glide
SE A/C backplate with Zippers Max-Flow filter, Vance & Hines slip-ons, TTS MasterTune, Amsoil 20-50 in everything, Boyeson X-wing, Microtach, Street Bob mini-apes from Rounder, SE 180 rear tire, Superbrace, True-Track, Ricor Intiminators
Old 10-17-2009, 12:33 PM
jackyl's Avatar
jackyl jackyl is offline
Steve
good question i would like to know the break down also between both. jackyl
__________________
2006 StreetBoB
Wdg Frt End/21 x 3.25" Frt wheel,V&H Stagg./Chrome Sliders/Mustang solo & Corbin Dual Tour Seat/Linby Highway Bar/14.5 ApeHangers/Diamond Back Cables/2 Inch Tank Lift/Chrome Rockers & More
Old 10-18-2009, 12:54 AM
2004 Jeep Wrangler
My Garage
In the case of going to a 107" the Axtell cylinders are needed due to the amount of bore. They have a larger sleeve in them. They require the engine cases to be bored out to accept the larger cylinders.
If you want to go to a 95/103" you can have your cylinders bored out to 3 7/8". You don't need to get different cylinders. The SE ones are pretty much just bored out stockers. The stockers can even be bored out to 3.93" to get a 98"...Not sure what the total cubes are if you started with a 96" but I think it is around 107"
This is about what I paid...I can't remember
$150 cylinder bore
$150 true and weld crank
$250? timken bearing upgrade
__________________
-Chad-
Old 10-18-2009, 02:34 AM
kk6pg's Avatar
Quote:
Translated it means the cylinder walls are a hell of a lot thicker than stock or the SE ones. That means better heat transfer to the cooling fins and more effective base sealing surface so you wont have the hot spots and base gasket leakage problems that have plagued the SE motors.
The only barrels better than Axtell are Jims, but you need new cases for those since the head stud spread is wider. Are they worth it? You bet your ass if you plan on your motor staying together for any length of time.
__________________
Tags
107, axtel, axtell, build, cam, cylinders, davidson, engine, forum, harley, kit, kits, pistons, shovelhead, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
