New rear tire find for 4.5" rims???? See what you think....
Here is a tire that may be overlooked as an option for the Dyna 4.5" rims.
It is a full 7" wide inflated...which is more than the other options available for these rims....or so it has been my finding.
According to Pirelli, the Night Dragon is 6.6"wide..(167mm)...close to the stock 160 Dunlop I think. This tire is 178mm or .4 inch wider so it's a noticable difference.
I don't have the specs on the metzler 170 or the SE2 so can't compare those...hoping someone will help with the research futher.
The thing to notice about this tire specifically is the weight rating at 783lbs. That is lower, but not by much more than a few of the others... Some of the other tires are rated at 805lbs.
A diff of 22lbs.
Is that enough to not be used?
Another thing is this is a high mileage tire. Maybe not as sticky as some, but for those of you who want long mileage, and nice fat tire, this could be an alternative.
When I called Pirelli who makes metzler, and the tech told me that the metz's would get higher mileage than the night dragons....I thought maybe this tire is more like the metzlers as far as compound makeup.
Also, it's a radial tire.
Let me know your opinions....here is a couple links.
· W-rated for speeds up to 168 mph
· Radial construction gives this tire light, responsive steering with excellent control and feedback
· Specially formulated compound gets up to temperature quickly
· Exceptional grip, even in wet conditions
· Perfect for sport riding, touring and commuting
· Sidewall ID Information: CONTINENTAL 170/60ZR-17 M/C 72W CONTI FORCE
DIMENSIONS Inflated Width/Measuring Rim Width:7.0 in./4.5 in. Inflated Diameter: 25.6 in. Acceptable Rim Width:4.0-5.5 in. Deepest Tread Depth: 7/32 in. Balance DOT: Yes Directional Arrow: Yes Speed Rating: W-Rated up to 168 MPH
CAPACITIES AND CONSTRUCTION Load Capacity/Inflation Pressure:783 lbs./42 PSI Load Range: B Bias or Radial Ply: Radial Tread Plies/Material: 2 Nylon/2 Aramid Sidewall Plies/Material: Nylon DOT Approved for Road Use: Yes Tube or Tubeless: Tubeless
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
__________________
2007 Super Glyde -
a.k.a... the "Goddess Juice Express"
Glydiator,
If you do a search you'll find several posts about the Night Dragon tire. There's a few guys that have put them on but no one yet, at least to my knowledge, has gotten enough miles to accurately predict what kinda miles we can expect from them. I'm currently on my second SE180 and got about 7500 miles out of the first and looks about the same for the second.
