Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Dyna Glide Models
Dyna Glide Models Super Glide, Super Glide Sport, Super Glide Custom, Low Rider, Street Bob, Fat Bob and Wide Glide.
Sponsored by: True-Track Inc.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 09-11-2009, 04:20 AM
09DynaMan 09DynaMan is offline
Hang Around
Quote:
Originally Posted by fastkevin View Post
Huh?
Even the stock mapping is lacking. It's too lean down low, and too fat up top. Why would you want to raise the rev limiter on a motor that stops building power long before the rev limiter kicks in?
Proper mapping improves efficiency, which improves power, the power curve, and fuel mileage.
Agree totally
Forget about making changes before remap, a stock bike is already in dire need
get a tuner, and stop wasting your money
Try to imagine the most extreme changes you might ever make, and get a good tuner that can cope with that
then you will not join the (very large) club of people with 5 discarded tuners for sale (that few would ever dare to buy used, as the are an ELECTRICAL item)
I use tts and am happy
remember, poor man pays twice!!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 09-11-2009, 05:07 AM
Rakthi's Avatar
Rakthi Rakthi is offline
Prospect
Quote:
Originally Posted by 09DynaMan View Post
Agree totally
A+ !!!
__________________
2009 Cross Bones with some farkles.
Old 09-11-2009, 06:13 AM
maddghost's Avatar
maddghost maddghost is online now
Huh?
I have the stage 1 download and a pcV with 2/1 exhaust. I have yet to reach the rev limiter since the remap,but with the power gain from from my setup I find I can stay in a gear way longer and it just pulls pulls pulls.
My bike no longer makes as much power down low thanks to the bub7's,it's all mid and high range now! When I twist she goes at high speeds!
__________________
'08 vivid fatbob,
BUB7 2/1,
A/N big sucker,pcV,
dually switchblades, grips shifter and B-Pedal
SB solo seat for cruzin
Jackyl's 2"+Spacerjim's2"
Old 09-11-2009, 07:00 AM
Bobbed Out's Avatar
Bobbed Out Bobbed Out is offline
Prospect
2009 HD Dyna
Agree totally
Quote:
Originally Posted by Rakthi View Post
A+ !!!
glad to hear this cause i'm looking at using Master Tune TTS as opposed to anything else but i hadn't heard much feedback about it
__________________
Master Tune TTS
Custom Made High Flow Air Cleaner
85 hp 97 torque on the Dyno
Old 09-11-2009, 07:37 AM
Hang Around
Smile
Quote:
what the tts does is allow you to alter the settings of the ecm,
and in a wider range of areas than the hd sert/sest
the main difference is the vtune part of the software, that allows for improvements to std calibrations to better suit individual setups
it is also possible to save the std hd flash(albeit encrypted) so that you can always reload that later without trace
I find it the most logical approach
Old 09-11-2009, 02:29 PM
BlockHead96 BlockHead96 is offline
TTS is the only way to go! Don't forget, the TTS is made by the same person who made the SERT for HD! But the TTS is far superior..
__________________
Master Tune TTS W/ Yuill Bro's Dyno tune, Ness Big Sucker, Rineharts
08FXDL
USN USS Constellation CVA 64 Tonkin Gulf 71-74
Old 09-11-2009, 06:08 PM
man4mopar's Avatar
man4mopar man4mopar is offline
Quote:
Far superior for what? Stage 1? Stage 2? Full bore drag build?
The TTS is very good and I personaly rank it very high in my opinions of the management systems out there. But I would never concider it the far superior of all choices out there. DTT TCFI IID to name one offers great things to the table that the TTS/Delphi system doesn't/can't do.
OP You should be fine if your exhaust has baffles (not straight through) even with a aftermarket air filter/intake. It will not be optimal power wise but will run just fine and not have catastrophic failure as some will/have chimed. The high load areas are set rich to begin with and idle/cruise ranges are corrected by the 02 sensors. If not you will get a code, if a code is thrown you will have a problem. No codes and ride on.
(some pipes and 02 sensor placement can cause false readings. The stock header pipes OP has on are not a problem, as long as it has baffles of some kind.)
__________________
2006 Wide Glide
American suspension's Dragon Springer
Fabricated to fit softail rear bobtail fender
06 Night Train dish wheel with 200mm tire
And some other stuff
Old 09-12-2009, 12:21 AM
fastkevin's Avatar
fastkevin fastkevin is offline
Prospect
Quote:
FWIW, you don't need to do them both. The signal coming from your ECU(where your S1 download is) gets intercepted by the Power Commander, so your FI does what the PC tells it to, to give the fueling requirements the map calls for.
Your download basically has no input in the matter.
Also, your motor configuration is for low and mid-range. A tuner should smooth out the power curve, but it should also enhance the power flow, not change it around. I'd be curious to see if you're running too fat down low, and only cleaning out when it gets up in the rpm's. That would explain why you'd feel the power come on up top. Nobody in their right mind would rob bottom end on a Harley, and replace it at the top. They're low revving motors, and more importantly, really long stroke V-Twins. They're built to churn the power out down low.
Tags
2009, bob, change, davidson, ecu, efi, exhaust, fat, harley, importance, kit, remap, remapping, screamin, slips
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
