Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Dyna Glide Models
Dyna Glide Models Super Glide, Super Glide Sport, Super Glide Custom, Low Rider, Street Bob, Fat Bob and Wide Glide.
Sponsored by: True-Track Inc.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 08-09-2009, 03:14 PM
JoeGrapes's Avatar
JoeGrapes JoeGrapes is offline
Hang Around
Default remap ecu?
I've add SE II slip ons and a KN air filter. While I'm sure I'll add more to the bike, the motor is just fine as it is. Now I suppose I should remap the ECU. Every now and then I'll get some minor popping when I let off the gas but nothing bad. The plugs do seem to be running vary lean. Is it better to go to the dealer and get a Stage 1 remap done or go with an add on like PC III?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 08-09-2009, 03:51 PM
Ratty Ratty is offline
Prospect
The PCIII or similar route is by far the best bet!
Old 08-09-2009, 04:19 PM
ColdCase's Avatar
ColdCase ColdCase is offline
Senior Rider
Remapping the ECU is not necessary, it will adjust, don't waste your $$. If you want better performance or less heat go with something else, lots of choices.
Old 08-09-2009, 06:51 PM
WhiteSS WhiteSS is offline
Hang Around
2009 Harley Davidson Fat Bob
i was wondering the same thing. I have a SE slipons and heavy breather coming in. Dealer is telling me 200 for a download. I think I would rather just get the PCV from fuelmoto and pay a little more for the flexability.
__________________
www.myspace.com/shadycycles
Old 08-09-2009, 07:02 PM
JoeGrapes's Avatar
Hang Around
The performance is fine with the stock motor. I just don't want to cause any damage by running to lean, but I also don't want to spend $200 and get on the bike and say.......ummmm, it don't feel any different.
Old 08-09-2009, 08:08 PM
ColdCase's Avatar
Senior Rider
In closed loop the ECU will adjust to the correct AF ratio, same lean AF as when you drove it off the dealer's lot (the O2 sensor tells the ECU the current AF and the ECU adjust fuel delivery accordingly). Closed loop is ~ 1 to 60% throttle (most of your ride). The bike will run a little leaner than stock in open loop (e.g. WOT), but the mods listed should not make the bike run dangerously lean. You can check your plugs now and again to be sure.
IMHO, use the $150-$200 towards something like the V&H fuel pack, PCV, or TTS. If you think you may be upgrading the bike again and are handy around a laptop, the TTS is probably the best way to go. There are other choices, each with pluses and minuses.
Old 08-09-2009, 10:51 PM
SC-Longhair's Avatar
SC-Longhair SC-Longhair is offline
2007 Harley FXDWG
Adding a pcV will get you a slightly better throttle response, AND undo the chain to the dealer. They're very easy to update and plenty of tuners know their way around a power commander, if you do something major down the road that requires a dyno-tune.
You can also get the auto-tune module which is just that. It will tune itself. Haven't heard anyone not have a bad experience with TTS or pcV w/autotune.
Although, think about this. The less we buy at the dealer, the higher the prices will go on services, etc to compensate or they will eventually close them. No place to buy bikes. Interesting catch 22, isn't it?
__________________
It has some stuff
You can call me Vic.
Tags
change, davidson, dyna, ecu, filter, gas, harley, hd, o2, pops, remap, remapping, softail
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
