Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Dyna Glide Models
Dyna Glide Models Super Glide, Super Glide Sport, Super Glide Custom, Low Rider, Street Bob, Fat Bob and Wide Glide.
Sponsored by: True-Track Inc.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 07-20-2009, 11:32 PM
HollWood HollWood is offline
Hang Around
Default High flow feul elbow/highflow petcock? what do you think???needed
The Bike info is a 1998 fxd Carburated bike, everything is stock, i am going to install a stage 2 kit as follows:
Air Cleaner
Screamin' Eagle Evolution 1340 High-Flow Air Cleaner Kit
Harley-Davidson Part Number 29008-90A
$69.95
Evolution 1340 Breather Manifold Kit
Harley-Davidson Part Number 29310-93
$29.95
Carburetor Parts
Stock Keihin CV* modified using a
DynoJet Re-calibration Kit
Harley-Davidson Part Number 29045-97
$74.95
.045 Slow Jet
27170-89
$4.95
*The carburetor used on the 97 FXD was a previously dyno tuned carburetor from a 94 bike. This carburetor had been modified using a standard DynoJet re-calibration kit. DynoJet supplies several kits depending upon the year of the bike. Similar results have been produced using a Yost Power Tube and tuner kit.
Exhaust System
Screamin' Eagle Slip On Baloney Cut Muffler Kit
Harley-Davidson Part Number 80067-95A
$119.00
Ignition System
Screamin' Eagle Street Legal Performance Ignition Module
Harley-Davidson Part Number 32630-96
$114.95
Ignition Coil
Screamin' Eagle Performance Coil
Harley-Davidson Part Number 31653-97
$49.95
Plug Wires
Magnecor 8.5 mm Harley-Davidson Plug wire set
$24.95
Camshaft
Andrews EV-46 camshaft
$158.00 list price - Street price is around $120.00
Torrington B-138 cam bearing
$10.00 Street price
Nose-Cone gasket
$8.00 from your local dealer
Screamin' Eagle Adjustable Pushrod Kit - Chrome Moly
Harley-Davidson Part Number 17900-87
$76.95
Other Items
Harley-Davidson Double Platinum Spark Plugs or H-D Gold Spark Plugs
Harley-Davidson Oil Filter
Mobil 1 15-50w Synthetic Motor Oil (3 quarts)
Royal Purple 75w-90 Synthetic Transmission Oil (1 quart)
Harley-Davidson Chaincase Lube (1 quart
Other Items
Other riders have been able to produce similar results:
I am getting all the info and opions i can about a cv carb modifications, i am planning on doing a carb rebuild in hopes of finding a fuel concern and also getting the carb set up for a stage 2 install.
I am changing the sheet metal becouse i have repainted e bay set-up. I started to think about changing petcock to a high flow setup but i am not really sure i need it and am looking for opinions from others that have used them.
I am considering a pingle high flow petcock for the bike i am also thinking about installing a hgh flow elbow but i do not have any idea if it is actually needed the info is attached here.. What do you think ???
Keihin Hi-Flow fuel inlet elbow
[JCP-004]
Click to enlarge
New lower pricing! The Hi-Flow fuel inlet elbow replaces the stock molded plastic fuel inlet elbow used on all Keihin carburetors. The elbow is made of brass and is far less restrictive than stock and will not break.
CV EZ-Just idle needle
[JCP-001]
Click to enlarge
The CV idle mixture screw allows you to simply and easily adjust the idle mixture on the Keihin CVK40 carburetors used on all carbureted Big Twin Harley Davidson’s from 1990-2006 and XL Sportster models from 1989 to 2006. The CV idle mixture screw will also work on Kawasaki Vulcan models that use the CVK type carburetor. It has reportedly been installed on many other CVK style Keihin carburetors. I do not support installation on anything other than Keihin CVK 40's used on HD's and the Kawasaki Vulcan CVK. Installation on other CV's is not supported......
Current Reviews: 6
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Tags
2900890a, 3263096, carburetor, cv, davidson, eagle, feul, filter, flow, harley, high, kit, petcock, rebuild, screamin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
