Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Dyna Glide Models
Dyna Glide Models Super Glide, Super Glide Sport, Super Glide Custom, Low Rider, Street Bob, Fat Bob and Wide Glide.
Sponsored by: True-Track Inc.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 07-17-2009, 01:10 AM
dynarider1821 dynarider1821 is offline
Hang Around
Question carb spitting gas - HELP!
just moved to AZ from CT, 2000 Dyna Wide Glide. twin cam 88 with stock carb. biked failed emmisions, gas is spitting out of carb into air cleaner. the choke wont stay pulled out (might be a separate issue?)
How do I fix the carb? Is the float stuck? Does something else on the carb just need to be adjusted?
Thanks,
Ron
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 07-17-2009, 08:04 AM
DGDyna's Avatar
DGDyna DGDyna is offline
Senior Rider
I had this problem on a 2-stroke and it turned out to be a clogged exhaust pipe. Since this is a 4-stroke, think of what could force air from the engine back to the carb. Stuck intake valve???
Old 07-17-2009, 09:59 AM
redrubicon2004's Avatar
redrubicon2004 redrubicon2004 is online now
2004 Jeep Wrangler
My Garage
Sounds like you are just out of tune. Carb may just need an adjustment. http://www.harley-performance.com/ha...arburetor.html
The choke thing is pretty easy. Behind the choke knob bracket is a large nut, hold that in place while tighting the front nut. This will compress a bushing around the choke rod and give it a little more friction to hold it in place. Tighten it just enough to keep it out....Dont go crazy on it!
__________________
-Chad-
95", ported heads-1.9 int 1.625 ex, 37G cams, SE cam plate and pump, Welded crank, Timken bearing, 42mm Mikuni
Old 07-17-2009, 10:44 AM
seniorsuperglideE8 seniorsuperglideE8 is offline
Does spitting occur while the "enrichener knob is pulled out? Do you push in the knob after the bike is warmed up, usually a couple of minutes or a couple miles. Could be something as your plugs starting to foul or your intake valves not closing completely during the compression stroke.
__________________
tailhook seat plumber
02 FXD 95" BB, 203 cams, low restriction mufflers
05 FXDLI, stage 1, low restriction mufflers
Old 07-18-2009, 11:34 AM
Hang Around
Default Thanks
Thanks I will try to tighten the not on the choke.
The gas dripping from the air cleaner housing did get worse when I put the stock baffles back in the V&H pipes (I had thunder Header baffles in there that allowed better exhaust flow and deepened the sound of the pipes and made it louder while still having enough back pressure to stop the back firing and spitting upon decelleration).
I just ordered the the repair manual for my bike and will attempt to make adjustments before going back for a 2nd emmissions test.
I just looked at the link for adjusting the carb and I will try that. Would you also recommend me installing a stage 1 tuner kit? Does the EZ-Just mixture screw really make it easy to tune or is it unneccesary?
Old 07-18-2009, 12:49 PM
wescoot2 wescoot2 is offline
PGR Forum Moderator
Send a message via Yahoo to wescoot2
Sounds like you ne to re-jet your carb.
__________________
2001 FXDWG
1st Infantry Div 67-68
Old 07-18-2009, 01:25 PM
Y2KFXDman's Avatar
Y2KFXDman Y2KFXDman is offline
Hang Around
Quote:
Originally Posted by dynarider1821 View Post
Thanks I will try to tighten the nut on the choke...
Go easy; it's plastic... and NEVER, EVER lubricate that enrichener shaft.
...I just looked at the link for adjusting the carb and I will try that.
You should be able to drill out the plug whilst the carburetor is still mounted on the bike, if you use a Dremel tool and its flexible shaft, BUT....
I'd remove the bowl and clean up in there, first. Shoot carb cleaner up at the float-valve/seat area, remove the jets and soak them a minute. Be careful not to loose anything. Wipe the bowl, button it all up, and test ride.
There's no need to buy any parts without first ensuring everything is clean and tight.
__________________
Willard
FXR risers, '69FL shocks, satin chrome, LowRider seat, & detachables galore
2000 Super w/ FXDX graphics, Stage 1, SBDs, & Diamond Ice aplenty
Old 07-18-2009, 01:49 PM
MidnitEvil's Avatar
MidnitEvil MidnitEvil is offline
EZ-Mix screw is awesome for tweaking your carb.
__________________
My two favorite things - my wife & my Harley
Old 07-22-2009, 11:22 PM
Hang Around
Question rubbing alcohol in Harley????
has anyone heard of putting half a bottle of rubbing alcohol in ur gas tank with half a tank of gas to help u pass emmissions testing?
Old 07-23-2009, 12:06 AM
archergodwin's Avatar
archergodwin archergodwin is offline
Pretty much nothing is going to help ya, but a good running bike. I'm thinking you ought to start there first: get it running right and not spitting gas the wrong way... no doubt you failed emmissions.... sounds like way to much fuel. What does the local dealer recommend for jet size in your area of AZ?
__________________
'08 FXDC, plus stuff & things.
In Process: workin' on a theme. Gonna buy a little, and gonna fab a little
USAF Vet. 92nd Bomb Wing.
Tags
back, carb, carburator, carburetor, cleaner, davidson, gas, harley, motorcycle, running, spit, spits, spitting, start, tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
