Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Dyna Glide Models
Dyna Glide Models Super Glide, Super Glide Sport, Super Glide Custom, Low Rider, Street Bob, Fat Bob and Wide Glide.
Sponsored by: True-Track Inc.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 07-02-2009, 08:51 PM
devils haircut's Avatar
devils haircut devils haircut is offline
Default Help clearing this code...
P0113, IAT sensor voltage high/open. Any thought or experience? Thanks.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
Shogun Rua...the REAL LHW champ! What fight were the judges watching???
...09 RKC...
Old 07-02-2009, 10:19 PM
archergodwin's Avatar
archergodwin archergodwin is offline
Check your connection (Input Air Temperature), should be in your intake manifold, behind your throttle body.
__________________
'08 FXDC, plus stuff & things.
In Process: workin' on a theme. Gonna buy a little, and gonna fab a little
USAF Vet. 92nd Bomb Wing.
Old 07-02-2009, 10:43 PM
YellowHawk's Avatar
YellowHawk YellowHawk is offline
2006 Harley Davidson FXDI
Not sure what model bike you have but the following is from the 2006 Dyna Electrical Diagnostic Manual and may be helpful:
P0113 IAT sensor open/high
Check the following:
* Poor connection: Inspect ECM and harness connector [78] for backed out terminals, improper mating, broken locks, improperly formed or damaged terminals, poor terminal-to-wire connection and damaged harness.
* Perform 4.8 wiggle WIGGLE TEST to locate intermittents: if connections and harness check out OK, use a DVOM to check the intake air temperature sensor voltage reading while moving related connectors and wiring harness. If the failure is induced, the intake air temperature sensor voltage reading will change.
* Shifted sensor: Refer to table 4.24. This table may be used to test the intake air temperature sensor at various temperature levels in order to evaluate the possibility of a shifted (out-of-calibration) sensor which may result in driveability problems.
* An intermittent may be caused by a poor connection, rubbed through wire insulation or a wire broken inside the insulation.
Note: All voltage and resistance values are approxiamate (+/- 20%). Measure IAT sensor resistance between ECM terminal 7 and system ground (ECM terminal 26).
TABLE 4-24. IAT SENSOR TABLE
TEMP DEG C____RESISTANCE___VOLTAGE____TEMP DEG F
-20_____________29121________4.9__________-4
-10_____________16599________4.8__________14
0________________9750________4.6__________32
10_______________5970________4.3__________50
20_______________3747________4.0__________68
25_______________3000________3.8__________77
30_______________2417________3.6__________86
40_______________1598________3.1_________104
50_______________1080________2.6_________122
60________________746________2.2_________140
70________________526________1.7_________158
80________________377________1.4_________176
90________________275________1.1_________194
100_______________204________0.9_________212
If you need it, let me know and I'll post the troubleshooting chart as well.
__________________
2006 FXDI
SE Stage I A/C
V&H Big Radius 2-2
PCIII USB
Old 07-03-2009, 09:30 AM
Bump...
__________________
...09 RKC...
Old 07-03-2009, 09:41 AM
mud's Avatar
mud mud is offline
Moderator
2006 HD SuperGlide
Hold the button down for a few seconds.......... that clears the code.
if it does not appear again, it was historic
if you see it again it is current........ so then you follow yellowhawk's list (for starters)
go from there
mud
__________________
Tags
2009, air, davidson, harley, intake, sensor, temp
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
