I use 104 Oct boot, get at the auto store, been useing it fir about 2 months really dont feel any difference maybe a little more throttle response. but can use reg gas if I need to but haven' yet.
Yes it does clean the injectors.
I am a huge fan of Sea Foam. I use one ounce per gallon of fuel every 1,000 miles. I put several ounces of it in with the oil about 500 miles before an oil change.
I also use top tier gasoline.....shell, exxon, chevron ..... the fuel that has fuel additive cleaners in the fuel.
...I also use top tier gasoline.....shell, exxon, chevron ..... the fuel that has fuel additive cleaners in the fuel.
I usually try to find any Shell/Texaco or Chevron stations when out on a long run. Of course, any gas will work in a pinch, and one or two tanks is not going to hurt anything. I run Chevron almost exclusively, but have put some basic STP fuel system cleaner in on occasions.
__________________
'08 FXDC, plus stuff & things.
In Process: workin' on a theme. Gonna buy a little, and gonna fab a little
USAF Vet. 92nd Bomb Wing.
I never believed the hype about Seafoam but I finally decided to give it a chance.
My lawn mower is really neglected. I leave fuel in it over the winter, never change the oil or even check it (hey, the damn thing was less than $150 so why bother doing all that when it lasts for 3 years or so before I have to get another one)
Anyways it was running pretty rough so I decided it would be a good test to see if Seafoam would help. I poured some in the gas can before I poured it into the mowers tank and I'll be damned if it didn't smooth that thing out. It runs almost as smooth as when I bought it now, I'm not kidding.
I'm a believer now.
__________________
2007 Street Bob
V&H Short Shots, SE ac, PC III, forward controls
