i was looking in the baffle on my stock exhaust on my fatbob.
i saw that their was small holes inside( on the side of the baffle ).
i am thinking that if i remove those 3 rivet that i could pull them out
to inlarge the holes... hope i can get them from the out side..is their
any material inside...is it easy to do.. i just want a bit more sound without
drilling that plate at the end....
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
I know a guy who drilled out his baffle plate and removed the fiberglass packing and his sound was very nice. drill 3/32" holes so as to pass wire tests! He said the removal went well,just drill out the three rivets holding the baffle in and replace them when you are done!
__________________
'08 vivid fatbob,
BUB7 2/1,
A/N big sucker,pcV,
dually switchblades, grips shifter and B-Pedal
SB solo seat for cruzin
Jackyl's 2"+Spacerjim's2"
You know I've been thinking about the doing the same thing to my 08 street bob. I don't think it would hurt but what about if you don't have a fuel pack. Would it mess anything up?
As long as you have not changed your air cleaner you are good. The o2 sensors will adjust the air fuel ratio for you. Alot of people buy a pair of Xied's which are cheap quick and instantly fool your sensors to give more gas which will cool the temp.of your engine! I actually have a pair of Xied's I am not using "for sale"
__________________
'08 vivid fatbob,
BUB7 2/1,
A/N big sucker,pcV,
So when you remove the stock baffles do you drill ALL the holes 3/32,because theres ALOT of little holes???? And you said remove the packing also????? I have mine out as we speak and not sure,thanks Bob
I believe that he's referring to drilling the baffle end plate, hence his reference ton passing the wire test, IE; DOT sticking a wire up into the baffle to see if it's been removed.
__________________
Fords and Chevy's kill more people than guns do.
Let's ban them.
Guns cause crime like cars cause drunk drivers.
'08 Dyna Super Glide
(Wrecked, was run off the road by a PU Truck)
