Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Dyna Glide Models
Dyna Glide Models Super Glide, Super Glide Sport, Super Glide Custom, Low Rider, Street Bob, Fat Bob and Wide Glide.
Sponsored by: True-Track Inc.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 08-09-2009, 08:12 PM
tpuckett75 tpuckett75 is offline
Hang Around
i just recently did this to my bike. i bought a set of the tamper proof torx bits to remove the baffle screws. pulled out the baffles, took off all the fiberglass insulation, then drilled out 10 holes per baffle. i took a 1/4" bit and each time i drilled a hole, i would spin the baffle about 1/2" and move down about a 1/2" and drilled another hole. it worked really well for me.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
http://lh6.ggpht.com/_KGw_5Jv5NcE/SgpSdDfLPeI/AAAAAAAAACI/YP68CiYPJCM/s128/IMG_0017.JPG
2008 Street Bob
Old 08-10-2009, 07:31 AM
Gary7's Avatar
Gary7 Gary7 is offline
When you pull the baffles in the 09-10 Street Bob mufflers, or the Fat Bob mufflers, this is what you've got:
As you can see, there is a thick steel mesh welded to the baffles that prevents you from getting to the actual baffle tube to drill those holes out. (This mesh is there to protect the fiberglass packing from the exhaust blast.) You're going to have to cut it off before you can enlarge the baffle holes.
If you want your exhaust to be just a tad louder than stock and a bit more throaty sounding, just remove the fiberglass packing and reinsert the baffles. I tried that and like the results very much. Don't go by how the exhaust sounds to you on the bike. Get someone to ride your bike and you stand on the side of the road and listen. You'll be pleasantly surprised.
__________________
2009 FXDC in Vivid Black | CC Dyno Power mufflers | FLSTF 7" headlight | CVO Dyna seat | 4" Deluxe pullback risers | Black forward controls | Landmark shift linkage | LRB Z Plus pads | Nightrider 02 IEDs | Sputhe Positrac ...
The Super Glide: Showing shock and kicking ass since 1971.
Old 08-10-2009, 01:16 PM
ghostrider69's Avatar
ghostrider69 ghostrider69 is online now
Prospect
Are the rivets metal or aluminum? I want to replace the rivets with rivets and not bolts.
Old 08-10-2009, 01:34 PM
cmiller1014 cmiller1014 is offline
Hang Around
Just realized the rivets are towards the inside of the bike so there is no way to drill them out while the pipes are still on the bike. I was trying to save myself a little time but I guess that wont happen.
Gary7: Thanks a lot for posting that picture. That helps me better understand what I am working with. What exactly has to be done after you remove the rivets to allow you to get to the fiberglass packing?
__________________
2010 Wide Glide
Bought from St. Charles Harley in Missouri
I've come to the conclusion that most motorists react just like squirrels do while on the road. Don't expect anything less.
Old 08-10-2009, 01:45 PM
Prospect
Just pull the baffle from the pipe. Then you can remove the fiberglass. Atleast that is the way I have done it on other pipes.
Old 08-10-2009, 02:09 PM
joemacro65's Avatar
joemacro65 joemacro65 is offline
Senior Rider
Did it multiple times before I bought aftermarket exhaust. Tried a few different things to improve the sound and performance. Lastly, just cut the stock baffle and welded in a straight pipe with a washer to provide some back pressure. Ultimately, it sounded better but nothing really improved the performance as much as the new pipes.
__________________
08 Dyna Fat Bob
Black Pearl
V&H Staggered
SE Stage 1 AC
PC III USB
Kuryakyn Fwd Ctrl Extensions
Some chrome bling accessories
Old 08-10-2009, 02:53 PM
jluvs2ride's Avatar
jluvs2ride jluvs2ride is offline
Get a metal cutting hole saw and a drill extension. No need to take the rivets off unless you absolutely have to take out the packing.
I did this procedure w/the mufflers on the bike with a hole saw that fit the id of the outlet on the muffler. I don't remember the diameter, got it at Lowes. Just run it up in the baffle, holding it straight. It cut the plug out which amounted to little more than a metal disc effectivly giving me straight through glass pack mufflers. When the hole saw cut through, the plug was on the pilot drill of the hole saw.
__________________
Veterans Helping Veterans
Old 08-10-2009, 04:06 PM
WhiteSS WhiteSS is offline
Hang Around
2009 Harley Davidson Fat Bob
Quote:
Originally Posted by jluvs2ride View Post
Get a metal cutting hole saw and a drill extension. No need to take the rivets of unless you absolutely have to take out the packing.
if you leave the pipes on, what do you do with the metal shavings? Turn the bike on and roll the throttle till they blow out?
__________________
www.myspace.com/shadycycles
Old 08-10-2009, 05:19 PM
Cajun Fat Bob's Avatar
Cajun Fat Bob Cajun Fat Bob is offline
Prospect
i tried removing the baffles on my fatbob and drilling them out...i thought it sounded horrible...it sounded almost like something was loose or a weird rattle or something..and my buddies agreed..so i took out the baffles all together...i am thinking of going with a thunderheader at some point...but it does sound awesome with straight pipes...
__________________
Old 08-10-2009, 05:38 PM
billjoat's Avatar
billjoat billjoat is offline
Prospect
2010 HARLEY DAVIDSON FXDWG
My Garage
"As you can see, there is a thick steel mesh welded to the baffles that prevents you from getting to the actual baffle tube to drill those holes out. (This mesh is there to protect the fiberglass packing from the exhaust blast.) You're going to have to cut it off before you can enlarge the baffle holes."
First off, thanks for a great picture of the baffle. I assume the fiberglass in question was wrapped around the mesh in several layers??
Tags
2009, air, baffl, baffles, bob, davidson, dyna, fat, fatbob, fuel, fxdf, harley, hurt, it, remove, removing, rmoval, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
