While riding today I noticed the my right turn signals started flashing very fast. They are normal for a few seconds and all the sudden they take off. It does not seem to be very consistant. when I got home I could not get the signal to speed up. Very weird. Would a loose connection cause this? Any ideas?
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
I figured the kury instructions would have mentioned that I need an equalizer for the led brake light install. I thought only LED turn signal required the equalizer.
I don't know for certain, but seeing as you added the taillight and then your problem started it is most likely related. I guess you should contact Kury for more info. I doubt it is a loose wire, but you never know.
Is it the turn signals themselves or the indicator light? My indicator light for the turn signal did the same thing week and I discovered i had a burnt out front bulb.
__________________
2005 FXDLI
Stage I, Mid-Glide Conversion, D&D Exhaust, Progressives front & rear, and lots of shiny stuff.
Wiegs,
You shouldnt need an eq for the brake light alone. Better start chasing turn signal wires. Look and see which light isnt working and thatll tell you the direction you have to go. Theres a pinched wire or shorted socket in there somewhere
__________________
08 Superglide Posercycle
With a bunch of useless stuff that makes me think I look cool
08 XL1200 Low 105th (for mama)
Just because the design is 100 years old, doesnt mean there hasnt been a few improvements
Turn signals will flash 4 times at normal speed, and then almost triple the flashing rate when something is wrong. Such as a burnt out bulb, no connection type of thing.
__________________
'08 FXDC, plus stuff & things.
In Process: workin' on a theme. Gonna buy a little, and gonna fab a little
USAF Vet. 92nd Bomb Wing.
