Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Dyna Glide Models
Dyna Glide Models Super Glide, Super Glide Sport, Super Glide Custom, Low Rider, Street Bob, Fat Bob and Wide Glide.
Sponsored by: True-Track Inc.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 03-03-2009, 08:48 PM
Pixs's Avatar
Pixs Pixs is offline
Prospect
Hi Jim,
There is a problem that you have that they may fix for you on their dime. You will need to have the inner primary case, transmission cover and possibly the transmission rebuilt. There is a known problem that the MOCO knows about. I really don't think that it is appropriate to discuss it here, I posted my experience here and it was taken out of context and my dealer had to deal with a screaming mainiack that had a different problem.
PM me with your phone number and I will dig up the paper work and history and answer as many of your concerns as possible.
Best Wishes,
Pixs
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
Best wishes,
Pixs
Old 03-11-2009, 07:16 PM
jimw411's Avatar
jimw411 jimw411 is offline
Senior Rider
I went to the dealer today where i had purchased my bike and also had the previous primary bearing replaced. The Girl that works at the service dept which had helped me in the past with another issue on my bike was extremely helpfull once again. She had the tech that did the first bearing replacement come over and listen to my bike to verify it sounded like it's going out again and she then called up Harley to see what they can do. The parts have been ordered and will be in next week. They will replace my inner primary case, primary bearing and bushing again and also remove my trans and put all new bearings inside and put it in the newer '07+ cases all FREE OF CHARGE.
I am so happy about this, Harley stands behind thier stuff and also i'm do for an oil change so the primary and trans will be done for free, all i have to do is the engine oil and i have a half quart left from last time so i only need to buy 2 quarts and a filter. Hell yeah.
__________________
2006 Dyna Super Glide
Old 03-11-2009, 07:30 PM
2002fxdp's Avatar
2002fxdp 2002fxdp is offline
has anyone tried putting a sealed bearing in?
or is the bearing the result not the cause?
Old 03-11-2009, 07:56 PM
jimw411's Avatar
Senior Rider
the bearing is the result of the case mis-allignment, so it's not a problem. And the purpose of the bearing and the bushing is so the inner primary case can be taken off easily to change the belt. I dont see how they could press the bearing onto the shaft and into the case.
__________________
Old 03-11-2009, 08:28 PM
galaxiedriver's Avatar
galaxiedriver galaxiedriver is offline
Hang Around
Quote:
Originally Posted by jimw411 View Post
I have a 2006 Super Glide that was built FEB -2006, my inner Primary bearing failed at 14,500 miles and it was replaced for free about 3 weeks before my warranty was up. now a year later with 18,500 it's making noise again just like it did before. I spoke to the dealer which is 40 miles away and they said i will have to leave it there because the manufacturer requires them to do tests and check things over. I'm just worried i'm going to take it there and they will tear into it and not cover and try to charge me. I do have the knowledge and means to replace the bearing myself but don't feel i should have to pay for it, and i want the problem thats causing it to fail to be corrected. I think it's BS that i'll be looking forward to changing my primary bearing every oil change as long as i own the bike.
Anybody had it replaced a second time out of warranty???? and have the problem solved????
Has this defect been designed out or is it still a problem on later models? Is this like Ford and their spark plug ejection problem that they ignore?
__________________
Paul
2009 Super Glide Custom, Vivid Black
Spread my work ethic around, my wealth, what little you leave me after taxes, belongs to me.
Old 03-11-2009, 08:32 PM
AdrianVall's Avatar
AdrianVall AdrianVall is offline
Soo, what sound does it make when the bearing is going out?
__________________
06' StreetBob -- Thunderheaders -- AN big sucker -- PCIII -- Avons -- Superbrace -- And a buncha black!
92' Yamaha XJ600 Seca II - STOCK and fun!
22 and lovin' life!
Old 03-11-2009, 08:35 PM
mud's Avatar
mud mud is offline
Moderator
2006 HD SuperGlide
jim, are the new cases doweled?? (trans case to inner primary)
I've been suspecting this is the cause of the failures for a while now.
I'm real interested in hearing about doweling,
and if it holds up this time.
mud
__________________
Old 03-12-2009, 06:32 AM
PKellyMc's Avatar
PKellyMc PKellyMc is online now
1995 Jeep Grand Cherokee
My Garage
Location: Pacific Northwest; I'm a Beacon of Conservatism in a Sea of Liberals
Send a message via AIM to PKellyMc Send a message via Yahoo to PKellyMc
Mine went at 3900-mi. Sounds just like a car's [bad] throwout bearing, but opposite; on a car, you hear it when you push in the clutch; on the bike, you hear it clearly while idling in neutral, but the noise coasts to a stop when you pull in the clutch lever, starts up again when you let it out. Mine sounded like a metal-wheeled roller skate on a concrete sidewalk. It'll be REAL obvious when/if it happens to ya, Adrian. Haven't heard of any of them turning into catastrophic failures that leave you stranded. Rode mine 80-miles home from when I first noticed my noise...didn't sound any worse after the 80-miles.
__________________
Patrick, CAS*
Watch out for the Invisible Man. Who's he? You are. Remember, all motorists are Blind and Crazy; they can be counted on only to do the unexpected.
* Cheap-Ass Scotsman '06DWG, Stg-1, 546-mi, ebay - $12.5K, 2/9/08 Superstition Mtns.
Old 03-12-2009, 09:19 AM
archergodwin's Avatar
archergodwin archergodwin is offline
Quote:
I believe '07 up are okay. Redesigned cases ..etc.
__________________
'08 FXDC, plus stuff & things.
In Process: workin' on a theme. Gonna buy a little, and gonna fab a little
USAF Vet. 92nd Bomb Wing.
Old 03-12-2009, 10:05 AM
KBFXDLI's Avatar
KBFXDLI KBFXDLI is offline
Cool
The roller bearing that is used in this application is not able to handle any misalignment at all. So it is not the bearing design it has to be the issue with case or shaft misalignment which is why some people are getting multiple failures and many get nothing. I suspect some poor quality manufacturing issue with the case or shaft vendor for the moco which is why you should have both the shaft & case replaced when you do this repair.
I sent the pics of some of these failed bearings to a tramsmission roller bearing engineer that I have known for 25 years and he confirmed the cause is definitely a misalignment issue or an oversized shaft which increases the preload on the bearing. So, if you case is misaligned or your shaft has been manufactured a few thousandths over tolerance your IPB is going to keep failing. Best to replace both.
__________________
06 FXDLI
Many thanks to our people in uniform for it is their courage and sacrifice that makes our nation great.
Tags
2006, bearing, clutch, davidson, defective, dyna, engine, failure, glide, harley, primary, problem, sealed, super, throw, trans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
