Since I am swapping my tins out, thought I'd give everyone an inside look at your FI gas tank.
This will help you to replace a fuel pump or bad sending unit also.
This is my second time to disassemble and reassemble so I is a x-spurt!
I took these pics when I reassembled my new tank, but I'll do the write up like I'm tearing it down for better understanding.
1. I actually leave the tank on the bike to disassemble the guts since it's easier for me to work on, but as stated, I was actually reassembling this tank.
2. Remove your Speedo, etc and disconnect the wiring and vent hose from the top plate.
3. Remove the T20 bolts...this is a Street Bob tank by the way.
4. The cover will not lift straight up, you have a vent tube (top of pic) so you have to turn sideways and bring to the left of the bike. Under the cover, disconnect the wires and remove the gasket...it's not glued in place.
5. I take the sending unit out first. it's on the right side and locks in place near the top of the tank...slide it backwards to remove it from the clips.
6. It comes out easily.
7. Here is the fuel pump in place. It will slide forward from the clips.
8. The hardest part for me is disconnecting the gas outlet hose. It is just a squeeze connector, but never works right! I actually pop the fuel pump off the clips before I disconnect this...I'm actually reassmebling as I write this though. Make sure to put the O-RING on before assembly.
9. The only way I could get it out was to turn it 180°....use some finesse and be careful with it.
10. If you are swapping tanks, use a 7/8" wrench to remov the quick - disconnect / outlet hose.
10. There it is...all naked!
11. Here are your guts!
Something like this would have helped me out the first time I did it so maybe it will help someone else!
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
thanks for the write up Mascman
I wonder if we can talk Mud into putting together a how-to section that actually makes sense. The manual is nice, but nothing beats advice from someone thats been there
__________________
08 Superglide Posercycle
With a bunch of useless stuff that makes me think I look cool
08 XL1200 Low 105th (for mama)
Just because the design is 100 years old, doesnt mean there hasnt been a few improvements
